2006-10-26, 17:56
Hey there, new to the forums, but have been an extremely happy XBMC user for a long time. I've only got one problem that I can't get to the bottom of.
My Windows Media Player library contains both local music as well as music located on a FreeBSD fileserver running Samba. I have successfully connected Windows Media Player to XBMC using Media Player's UPnP library sharing. However, using XBMC I have only been able to listen to the music that is on the machine running Windows Media Player, any music located on Samba shares won't play. The files are listed when browsing the directories with XBMC, but they won't play. In Windows Media Player they play just fine as well.
I've read somewhere that you need to setup a samba user account "NETWORK" and give it read permissions for any share you intend to use through Windows Media Connect, but this doesn't seem to be working in this case.
Oh yeah, before you recommend an easier way or ask, "Why not just use Samba?" The reason I am not just using Samba shares is because I want the new Windows Media Player library sharing gives you complete access to all your playlists and star ratings and what not. Pretty handy.
Thanks in advance eh!
Nathan
Nathan
