Full Version: BlueTheme for Amber
Pages: 1 2 3
I just registered to this forum just to say thank you for this skin...i really like it. BTW @wargo any chances you can update to fully support Jarvis or reflect the original version of Amber...?
TIA
(2016-02-27, 08:30)storm119 Wrote: [ -> ]I just registered to this forum just to say thank you for this skin...i really like it. BTW @wargo any chances you can update to fully support Jarvis or reflect the original version of Amber...?
TIA
+1
Now updated for Jarvis!
Very nice. I like the blue color. Just have got one issue. When any dialog comes the background is blueish white and the text is white. So it is hard to read it sometime. Can you reduce the contrast or whiteness to the background.
Or please let me know where I can do that.
(2016-04-25, 23:40)ace310 Wrote: [ -> ]Very nice. I like the blue color. Just have got one issue. When any dialog comes the background is blueish white and the text is white. So it is hard to read it sometime. Can you reduce the contrast or whiteness to the background.
hello, do you mean this white on white?
(2016-04-26, 00:59)wargo Wrote: [ -> ]
Yes and as well the opening stream dialog or confirmation dialog. If you want, I can send in the screenshot as well once I go home.
Check the image for filemanager. See how the selected file or folder text is hardly visible. Also, check when we go to addons.
(2016-04-26, 06:22)ace310 Wrote: [ -> ]Check the image for filemanager. See how the selected file or folder text is hardly visible. Also, check when we go to addons.
Should be good now, just re-download it
Cheers
(2016-04-26, 15:02)wargo Wrote: [ -> ]
Cheers
Ok. Thanks. Will try out later and report back.
Edit 1: Looks good. Thanks.
Can we have the update for latest version please? I love blue theme, I hope it becomes part of original skin.
Or can you guide me the changes?
Latest update available 2.2.8 on the first post
Thank you very much. Will give it a shot.
(2016-07-25, 23:11)ace310 Wrote: [ -> ]Thank you very much. Will give it a shot.
if you can also give me a feedback on my new other mod would be great.
http://forum.kodi.tv/showthread.php?tid=283773
Nice work Smile
Any possible to update this MOD to work on Krypton?
what's the latest Amber release for Krypton? 2.2.8?
Pages: 1 2 3
