Full Version: BlueTheme for Amber
Pages: 1 2 3
27/07/2016
Krypton Version based on Amber 3.0.2
http://www.mediafire.com/download/c5m8dn....3.0.2.zip
21/07/2016
Latest update available 2.2.8
http://www.mediafire.com/download/wah88o....2.2.8.zip
25/04/2016
Hello guys!
Jarvis update 2.2.5
http://www.mediafire.com/download/b43lyz....2.2.5.zip
28/08/2015
update 2.1.2
cheers
http://www.mediafire.com/download/14g3r2...eTheme.zip
23/08/2015 Update to amber 2.1.1 for Isengard
Hello,
It should now work on Isengard,
I replaced the backgrounds with some of these ones colorized in blue, hope you guys like them.
http://forum.kodi.tv/showthread.php?tid=137846
here is the download link
https://www.mediafire.com/?laa0uuqoq456wqc
Cheers
Updated 20/06/2015
Hello, I now created a full skin zip file, including the blue theme.
It's based on the 2.0.17 for Kodi 14
This should allow the installation from zip file for android.
I also included the sub menus posted here
http://forum.kodi.tv/showthread.php?tid=187051
thanks to .:B:.
here is the link:
http://www.mediafire.com/download/1rau97....amber.zip
Hello!
here is a blue theme for Amber Skin, hope you guys like it!
https://www.mediafire.com/?ci5pg8247wqt2ab
copy BluTheme.xbt to
\addons\skin.amber\media
copy Cyan.xml to
\addons\skin.amber\colors
It works....Looks great.....thanksBig Grin
Thanks!!
wow, very nice...
how on android?
Could this be added to the official version?
Nice, although would have been nicer still if Mediafire hadn't spammed me with a very dodgy pop-under tab trying to convince me that my browser had a problem and I should run a security scan with them to fix a non-existent problem (at least my machine wouldn't have had a problem until the scan had probably snuck in all sorts of malware).
Very much not inspiring confidence in the whole deal unfortunately, especially as the page was coded with pop-ups such that the only safe way to get rid of it was to nuke the browser instance and start again. It may be nice to consider somewhere more reputable to host the files?
(2015-06-03, 21:20)DarrenHill Wrote: [ -> ]Nice, although would have been nicer still if Mediafire hadn't spammed me with a very dodgy pop-under tab trying to convince me that my browser had a problem and I should run a security scan with them to fix a non-existent problem (at least my machine wouldn't have had a problem until the scan had probably snuck in all sorts of malware).
Sorry about your problem, but MOD pages I've looked around the forum is either posted on github or mediafire, never seen anyone complaining about it...
here some pages of Aeon Nox Mods posted on Mediafire
http://forum.kodi.tv/showthread.php?tid=209412
http://forum.kodi.tv/showthread.php?tid=212324
(2015-06-03, 18:14)spaziomilano Wrote: [ -> ]how on android?
I can copy the theme into the official skin zip file and then you can install the skin from zip, should it work?
Updated 20/06/2015
(2015-06-04, 13:03)wargo Wrote: [ -> ]
(2015-06-03, 20:09)pettson3816 Wrote: [ -> ]Could this be added to the official version?
That would be awesome. Thank you.!
Edit: it's already done I see. Thanks again.
Hi, are you going to release an update when original Amber for Isengard will be ok? Thanks
+1 for update for isengard release
(2015-08-16, 20:18)freddy12 Wrote: [ -> ]+1 for update for isengard release
now updated for Isengard!
I love the Amber skin in general and love the idea of a different color theme. This looks amazing.
Now i dont want to be an annoying person requesting random stuff from people a lot smarter then her. so i just want to know if its not too much trouble. How hard is it, how much do i need to change and in which xml's to get the vertical main menu to be just a little narrower? its probably the one thing that bothers me with an otherwise perfect skin.. There is no need for it to be so wide :x
Pages: 1 2 3
