Full Version: OneDrive for KODI (Officially in Kodi Addon Repository)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Hello!
I'm having issues with Onedrive Add-on (Onedrive Business account). Since this afternoon, when I try to open my Onedrive folder, I see this error:
Does anyone know what could it be?
Thanks Smile
Hi tonystam, this should be fixed with version 2.0.0. Just waiting for kodi team to merge the new version in the repo.
(2017-11-09, 07:27)cguZZMan Wrote: [ -> ]Hi tonystam, this should be fixed with version 2.0.0. Just waiting for kodi team to merge the new version in the repo.
Thank you so much Smile
Has anyone been able to use this with an .edu one drive account? the free one from Microsoft that requires an edu email address?
My edu keeps giving me invalid url when going thru the steps. but my 5gb personal one works fine.  Strange thing was it worked at first and then disappeared from kodi.
Getting this in the url:
OneDrive+for+KODI27+is+currently+not+supported+for+your+organization+eduemail+because+it+is+in+an+unmanaged+state.+An+administrator+needs+to+claim+ownership+of+the+company+by+DNS+validation+of+eduemail+before+the+application+OneDrive+for+KODI+can+be+provisioned
Looks like it's a problem on your dns.
"OneDrive for KODI27 is currently not supported for your organization eduemail because it is in an unmanaged state. An administrator needs to claim ownership of the company by DNS validation of eduemail before the application OneDrive for KODI can be provisioned."
The admin should verify the dns. Look here for some info: https://docs.microsoft.com/en-us/azure/a...n-takeover
I'm using Kodi 17.6 and have v2.0 installed. I have successfully signed in but I can't access any of my files. I keep getting 'name' error.
Links to photo:
https://1drv.ms/i/s!AieLHoHJLhYKjo50lRC77i5ngqL43A
https://1drv.ms/i/s!AieLHoHJLhYKjo51LVyoaPCK-ZYCAw
What I am missing?
also, it was working fine until I had to migrate over to the new version. I've tried uninstall and reinstall to no avail.
I have the same problem
Hey guys, thanks for reporting the error. I already pushed the new version 2.0.1 few weeks ago in the kodi repository, but looks like the merge is gonna take a while.
This new version should fix your issue, so in the meantime I would recommend you to install it now by downloading it from the code repository: https://github.com/cguZZman/plugin.onedr...edrive.zip and then just install it manually.
Addons > Install from zip file > etc.
Let me know if your issue is fixed.
(2017-12-12, 05:44)cguZZMan Wrote: [ -> ]Hey guys, thanks for reporting the error. I already pushed the new version 2.0.1 few weeks ago in the kodi repository, but looks like the merge is gonna take a while.
It's working now!!!! Thanks!!!!
Version 2.01 from the zip file solved the issue.
Thank you so much!
not able to get "use as a source" to work, i used the path http://localhost:8585/... only worked for 5 mins then it broke, don't know what went wrong, reinstalling the add-on didn't help.
I have some videos stored on onedrive as RAR files, normally they don't show up in the add-on, but with the "use as a source" function i can get them to play. And BDISOs work pretty well too using this trick.
Any idea on how to fix it?
@nyjoker are you getting an error message? did you added the source as http://localhost:8585/source/ ? Which version of the addon you are using?
http://localhost:8585/source/ works, thank you very much, the old path http://localhost:8585/ worked on the first run, then I couldn't get it to work again, but now it's all good.
Hey
OneDrive is not working on my Xbox One. When i click on add an account it will come up with pop up box saying;
Unknown error:<urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)>
Please try again.
Any fix for thisHuh
NOTE: Exact same error when trying to add an account with Google Drive.
