2018-12-18, 03:57
2018-12-18, 09:44
I can not play onedrive video,too.
2018-12-18, 20:12
i have just add new account by onedrive, it showes i have not enough permission to access it 。so maybe my account supplier have limited my permission to connect。
2018-12-23, 11:56
Hello,
i’ve Updated to the new Onedrive Addon. I’m on the same WiFi network from my mobile to my Kodi box but whenever I enter the auto code from the website I get this message:
Authenticate Your Kodi
Your code is invalid. Make sure you entered the code displayed in Kodi and you're in the same network as your kodi device.
2018-12-24, 22:46
Just checking to make sure my post can be seen. Not sure what to do on the above issue.
2018-12-27, 16:29
@thomasmaster you need to post your debug log file too.
@kitkat3ny it's probably because your internet provider is changing your ip address very often. Can you verify? You can go to https://drive-login.herokuapp.com/ip to check what is your public ip, then refresh the page after about 15 seconds to see if it changes.
Otherwise, post your debug log file when you are adding your account and also send me a PM with the result of the url that I gave you above.
2019-01-02, 13:21
Thanks for your reply.I forget to post my log file before. Here I upload the log file https://paste.kodi.tv/ajanozemed , and please allow me to descripe my problems again. Seveal weeks ago I find I can not play onedrive business cloud video with onedrive addon. It worked before. And it seem works fine in my onedrive personal account for now. By the way ,I also use cloudplayer to stream onedrive business cloud music,too. And now it can not play onedrive music,too. So,maybe onedrive business has changed somgthing to block streaming video i think. Again,thanks for your attention.
2019-01-03, 17:12
Same as above poster, cannot play video files in my Onedrive, when I click on movie, just spins then stops, then when I check the video files inside Kodi it says the bytesize of the file is 0KB. Here is my attached log file https://paste.kodi.tv/mikanojoke
Thank you @cguZZMan
Thank you @cguZZMan
2019-01-03, 17:18
Further to this, I can play the files using VLC from my Onedrive on my PC no problem.
2019-01-06, 11:06
(2019-01-03, 17:18)calisto Wrote: [ -> ]Further to this, I can play the files using VLC from my Onedrive on my PC no problem.Can you tell me how to use VLC to stream Onedrive videos?
2019-01-06, 17:58
(2019-01-06, 11:06)thomasmaster Wrote: [ -> ]Hi,(2019-01-03, 17:18)calisto Wrote: [ -> ]Further to this, I can play the files using VLC from my Onedrive on my PC no problem.Can you tell me how to use VLC to stream Onedrive videos?
I have got Expandrive set up on my PC & the program makes your cloud drives part of your system.
https://gyazo.com/2fe40fbd3fbeafe9e4e0df365834f7c8
2019-01-07, 12:05
(2019-01-06, 17:58)calisto Wrote: [ -> ]I tried and succeeded. Thank you!! Hope one day onedrive addon will work again.(2019-01-06, 11:06)thomasmaster Wrote: [ -> ]Hi,(2019-01-03, 17:18)calisto Wrote: [ -> ]Further to this, I can play the files using VLC from my Onedrive on my PC no problem.Can you tell me how to use VLC to stream Onedrive videos?
2019-01-08, 23:44
my computer is setup to connect through a proxy server, it seems that the add-on doesn't work with either the Windows proxy setting or the kodi proxy setting,
will proxy support be added in the future release?
2019-01-20, 18:58
@thomasmaster @calisto looks like OneDrive for Business changed some api responses. I'll try to find some time to fix it.
OneDrive for personal accounts is working fine.
@nyjoker the addon doesn't implement proxy functionality. That comes from Kodi. Have you seen any addon implementing proxy support?
2019-01-20, 19:46
(2019-01-20, 18:58)cguZZMan Wrote: [ -> ]@thomasmaster @calisto looks like OneDrive for Business changed some api responses. I'll try to find some time to fix it.Great to have you back & look forward to seeing if you can fix the problem.
