Hi guys,
1. I'm using the Onedrive addon as a source to my Kodi Video library without exporting the .strm files to a local folder on my Mibox. (The reason for this is that I want the subtitle files to be available on the Onedrive folder of the movie so all users can have access to it and not have to worry about downloading and finding the right subtitles file.) My question is how do I set as a Source to the Video Library a specific folder within my Onedirve for business? The folder on my Windows Pc is: Oncedrive - MybusinessName\Movies but I can't seem to create it as a Source for the Movie library as I don't know the exact path to use with
http://localhost:8586/source/?
2. Is there a way to setup the subtitles to load up automatically if they are sitting on the same folder as the movie on Onedrive?
thanks from Melbourne downunder guys.
Hello,
i like the OneDrive addon very much. Unfortunally I got this error today:
Unknown error:
'AccountManager' object has no attribute 'load'
Please try again.
Can someone help me?
Reinstall and new account registration with
https://drive-login.herokuapp.com/ did not change it.
Many thanks
RealMentis
get the latest version from my repo.
and always post a debug log file if you want to report an issue.
(2015-06-01, 04:35)cguZZMan Wrote: [ -> ][*]Playback your music and videos. Listing of videos with thumbnails.
This working great for browsing by folder and playing back videos, but I’m not seeing any thumbnails. In fact the only view options I’m given are IconWall and WideList.
How can I enable thumbnails when browsing through the folders without adding the shows to a library?
Hey there.
Quuck.question.
Dies this plugin Support Isos?
The problem is.. i have made a bluray from.a few short movies. Made them with chapters and main-menu-screen etc.
If I start Kodi on my Smartphone and choose the file from my internal storage, everythings works fine, if I start the plugin and start the file from my.onedrive account. It don't start.
Thanks for your Help.
is it an .iso file? single file? i have tested them and they work. Without a menu tho.
Anyway, try to use formats that are ment to stream, like mp4 or mkv.
Hi guys,
Anyone had any luck with Onedrive on a Shield/FireTV Cube running Kodi 19 Matrix streaming their MP3's?
I got it to work on Windows Kodi 19 but mirror copy of the code it just hangs under android.
BTW spaces in the file names for MP3 files are a pain. I edited them to %20 along with all the other special unicode characters URLs escape.
I had to build the dB locally with the files then edit the path to onedrive to populate the dB under windows.
Hi All!
So I' am running Kodi on Ubuntu 20.04 and have the OneDrive Add-on installed. It's working well for Pictures, but am having problems establishing my OneDrive music folder structure as a Music source. It seems that it just defaults to trying to find Video media. I tried entering the
http://localhost:8586/source/ address as a new Source, but it still can't find music (still looks like it is scanning for videos). I've had success adding music from Files, but I can't find a way to scan all of the subfolders (in the standard iTunes structure Artist/Album/Songs) in one go. I would have to scan each individual Artist folder! (I have 303 artists.) Am I missing something?
This is more of a heads up / FYI reply for users having buffering / freezing issues with the plugin.
Am using it on the latest build of KODI on both Nvidia Shield TV and Amazon Fire TV Stick 4K devices.
We have a virgin media 500mbps internet connection, however even with relatively small files
(both mkv and mp4) KODI would buffer, freeze, complain the source wasn't fast enough.
As you can imagine, this was confusing as both physical devices and internet connection are more than optimal!
On a hunch, I changed my routers DNS settings to use Googles
8.8.8.8 and Cloudflares
1.1.1.1
OMG, the difference was dramatic to say the least. The OneDrive folders would display much faster, scrubbing through videos was much faster and zero buffering or freezing even when playing 4K content from OneDrive.
Bottom line, my experience of this plugin was greatly improved both in stability and peformance by using alternative DNS to my ISP's
only allow 2 user 1 onedrive acc?
Is this plugin still working?
Using Fire stick.
I've tried using the and the sister GDrive plugin with the same result. It's scans in the my music but nothing shows within Kodi. I tried using an old version of Kodi with the same result.
Any suggestions?
Hi guys,
I'm trying to add an account to the OneDrive add-on. I'm scanning they QR code with my phone but keep getting error code "the code is invalid" and I can see the source ID is different between my TV and my phone. I have verified I'm on the same WiFi network, I have restarted both devices. Any ideas what could be causing this issue?
All advice much appreciated
Roy
Hello, so far I have used Kodi 18, where the OneDrive source worked fine. I upgrade Kodi18 to Kodi Matrix (19.3).
Since the update "http 303, http 406, etc." errors have been displayed in the log.
On all devices on which I have updated Kodi. (Xbox, PC etc.)
The video will start, but it will only take a few seconds and Kodi will freeze after that.
https://paste.kodi.tv/aniqumuyox.kodi
What can I do?
Problem solved:
advancedsettings.xml:
<network>
<disablehttp2>true</disablehttp2>
</network>
