Full Version: OneDrive for KODI (Officially in Kodi Addon Repository)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
(2021-11-29, 00:17)solyomb Wrote: [ -> ]Problem solved:
advancedsettings.xml:
   <network>
    <disablehttp2>true</disablehttp2>
  </network>
Couldn't get this working on Nvidia Shield running Android 11 even by creating the xml as described and pasting it in
Android › data › org.xbmc.kodi › files › .kodi › userdata
looks like the dev has abandoned this plugin
https://github.com/cguZZman/plugin.onedrive/issues/63
This advancedsettings.xml fixed the problem for me..
<advancedsettings version="1.0">
    <network>
    </network>
</advancedsettings>
(2022-03-08, 22:46)biglife Wrote: [ -> ]advancedsetting
Sweet, worked, thank you :-)
it works... thanks
I have the following issue:
I registered the account as normal. I can access my data.
But when I use a python skript to start a slideshow at boot I get the following error message: "This account or drive is not registered. Do you want to add an account?"
import xbmc
xbmc.executebuiltin('SlideShow(plugin://plugin.onedrive/?action=open_folder&driveid=<DRIVE ID>&item_id=<ITEM ID>&content_type=image&child_count=0)')
any suggestions?
