Full Version: fetching issues
hi i have just added some tv shows to test, and i have the original TMNT cartoon series from the early 90's but it has fetched some series from 2012.... is there away i can tell it to fetch info for the right TMNT?
cheers
Hi
What are the file names you have? for each episode?
I presume you mean this TV series?
https://www.themoviedb.org/tv/160-teenag...s/season/1
in which case does the following work?
Folder: Teenage Mutant Ninja Turtles
subfolder: Season 1
File: Teenage Mutant Ninja Turtles (1987) S01E01
