Hi everyone. My name is deanie44 and I am new to the forums. I love Kodi. I just install NextPvr addon in Kodi, I think I did everything correctly by watching a video on Youtube. Here's the thing--I have no tv guide listings. I can watch live tv and switch channels, but when I click on the epg it is blank. What could be the problem? Should I reinstall the NextPvr addon? I am using Windows 7 x64. Should I uninstall WMC? Any assistance will be helpful.
Thank you deanie44
Do you have the guide working in NextPVR itself? If not, then you haven't set up the EPG, and won't get it in Kodi either.
Hi sub3. I have a tv guide in NextPVR, which is the channels I receive in WMC. The guide in Kodi is totally different.
The channel numbers are not the same a WMC. How can I get the channel numbers to match the listing in WMC or NextPVR? I am the Eastern time zone.
Thanks deanie44
Maybe try making sure you have 'use channel numbers from backend' selected in the Settings - TV - General screen (need to have settings level set to 'Advanced'), then do a 'reset pvr database'.
sub3 you are a superstar. It worked. Thank you. deanie44
(2015-06-05, 21:47)deanie44 Wrote: [ -> ]sub3 you are a superstar. It worked. Thank you. deanie44
Still true after all these years. This fixed my incomplete guide from npvr.
