2015-06-03, 03:41
Sorry if this has been addressed before but I am having an issue whereby, for example, a TV show called Forever is not getting picked up during the Library refresh even though it does exist in IMDB. http://www.imdb.com/title/tt3487382/
• My folder structure is exactly the same as all other TV shows, so it’s not that.
• The naming convention of the file is also as per the recommendation. (I have even renamed with File Bot, which successfully connected to IMDB and renamed the shows successfully, (which makes it even more confusing as I know IMDB is picking it up in filebot and renaming successfully)
I have tried to manually refresh the folder and select the option that comes up, but for some reason the option to select Forever (Year Made 2014) is not an option to select. And yet it is on the IMDB site!
Now interestingly enough, the above show did get picked up when I was using Gotham, but not in the latest stable release of Kodi.
This also happens with the TV show Empire.
http://www.imdb.com/title/tt3228904/?ref_=fn_al_tt_1
I don’t understand why it is not getting picked up either automatically during a refresh, or when I try to manually refresh, and select the options that the Scraper supplies, or try to manually search the name of the show with Forever 2014 for example.
Thank you all for any guidance and or assistance you may be able to provide!
Cheers Mark
System1:
Raspberry PI2
Openelec
XBMC 14.?
Thecus EVO4100 NAS serving the files via the NFS function
System2:
HTPC
Windows 7
XBMC 14.?
Local Hard Drive with the TV shows on it.
Cheers Mark
System1:
Raspberry PI2
Openelec
XBMC 14.?
System2:
HTPC
Windows 7
XBMC 14.?
