Thank you I will try
Seemed to work - is there a Kodi Interface update command as well? I didn't see it in the guide from the first post.
Hi @Dan,
What's the correct way to scan and scrape just a movie folder instead of doing a complete library scan?
I'm running the following command-line:
"D:\\EmberMediaManager\\Ember Media Manager.exe" -profile redglory -scanfolder "M:\\Movies\\Walking Out (2017)"" newauto all -nowindow
But my EMM log says:
2017-11-11 14:40:58.0216;EmberAPI.CommandLine;EmberAPI.CommandLine.RunCommandLine;1;WARN;[CommandLine] Invalid command: newauto;
2017-11-11 14:40:58.0216;EmberAPI.CommandLine;EmberAPI.CommandLine.RunCommandLine;1;WARN;[CommandLine] Invalid command: all;
And nothing is being scraped...
(2017-11-11, 16:41)redglory Wrote: [ -> ]Hi @Dan,
-profile redglory -scanfolder "M:\Movies\Walking Out (2017)" -scrapemovies newauto all -nowindow
(2017-11-10, 03:09)NewYears1978 Wrote: [ -> ]Thank you I will try
No, there is no command, but it runs automatically if you've enabled
RealTime Sync in KI host settings.
Thanks I will try it when I get home
Edit: works great!
Enviado do meu ONEPLUS A3003 através de Tapatalk
(2017-11-11, 17:36)DanCooper Wrote: [ -> ] (2017-11-10, 03:09)NewYears1978 Wrote: [ -> ]Thank you I will try
No, there is no command, but it runs automatically if you've enabled RealTime Sync in KI host settings.
Ah, I do have those checked..I never noticed it doing that on it's own - I will test next time I have a new show, thank you
(2017-11-12, 05:15)NewYears1978 Wrote: [ -> ] (2017-11-11, 17:36)DanCooper Wrote: [ -> ] (2017-11-10, 03:09)NewYears1978 Wrote: [ -> ]Thank you I will try
With
RealTime Sync enabled, the KI sync every time if Ember save something to his own database.
Hi @Dan,
Just to clarify one thing.
For new tv shows to be scraped correctly one would run the following command-line:
"Ember Media Manager.exe" -profile redglory -updatetvshows -scrapetvshows newauto all -nowindow
and for new episodes in an existing TV Show we would run:
"Ember Media Manager.exe" -profile redglory -scanfolder "T:\TV\The Exorcist" -scrapetvshows newauto all -nowindow
Is this the correct way?
(2017-11-12, 20:39)redglory Wrote: [ -> ]Hi @Dan,
First yes, second no. It's not needed to start a scrape for new episodes, if the shows has already been scraped. Episode scraping will run automatically while database update, so you don't need to do more then:
"Ember Media Manager.exe" -profile redglory -scanfolder "T:\TV\The Exorcist" -nowindow
(2017-11-12, 20:51)DanCooper Wrote: [ -> ] (2017-11-12, 20:39)redglory Wrote: [ -> ]Hi @Dan,
Makes sense! Thanks a lot
redglory May I ask why you use -scanfolder instead of running a global update?
I use it as a script to update only that episode.
(2017-11-13, 20:56)redglory Wrote: [ -> ]I use it as a script to update only that episode.
PP script for nzbget? Just using
"C:\Ember Media Manager BETA\Ember Media Manager.exe" -updatetvshows would do the same
EDIT: I see you working on this
https://github.com/redglory/ember_media_manager get rid of couch and start using
radarr then just do this
(2017-11-13, 18:37)Fail$tyle420 Wrote: [ -> ]@redglory May I ask why you use -scanfolder instead of running a global update?
It's much faster than scan the whole tv show library. I do the same for all folders with new episodes, but I use the context menu entry in Windows Explorer.
(2017-11-13, 22:12)DanCooper Wrote: [ -> ] (2017-11-13, 18:37)Fail$tyle420 Wrote: [ -> ]@redglory May I ask why you use -scanfolder instead of running a global update?
Yupp, that's why I use it.
I've set it as a Sonarr post-processing script
I'm updating it to first query kodi to find if the TV Show is already in kodi's library. If not, run the script with the -updatetvshows -scrapetvshows command-line options
