Full Version: CommandLine
Pages: 1 2 3 4 5 6 7 8 9
My scripts are:
Radarr
Link
Sonarr
Link
os.environ.get('EmberMediaManager') is set to
python:
D:\\EmberMediaManager\\Ember Media Manager.exe
My last log on Sonarr:
python:
pythonw.exe at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
pythonw.exe at System.Windows.Forms.Control.WndProcException(Exception e)
pythonw.exe at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
pythonw.exe at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnUnhandledException(UnhandledExceptionEventArgs e)
pythonw.exe at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.raise_UnhandledException(Object sender, UnhandledExceptionEventArgs e)
pythonw.exe at Ember_Media_Manager.My.MyApplication.MyApplication_UnhandledException(Object sender, UnhandledExceptionEventArgs e)
pythonw.exe at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
pythonw.exe Unhandled Exception: System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
pythonw.exe ERROR:EmberMediaManager:Ember Media Manager failed with: 255
pythonw.exe INFO:EmberMediaManager:Ember Media Manager: running on PID: (9716)
pythonw.exe INFO:EmberMediaManager:TV Show Internal ID: 128
pythonw.exe INFO:EmberMediaManager:TV Show TVDB ID: 253463
pythonw.exe INFO:EmberMediaManager:TV Show Full Path: T:\TV\Black Mirror
pythonw.exe INFO:EmberMediaManager:TV Show Title: Black Mirror
pythonw.exe INFO:EmberMediaManager:Starting Ember Media Manager with application arguments: ['D:\\EmberMediaManager\\Ember Media Manager.exe', u'-profile', u'redglory', u'-scanfolder', u'"T:\\TV\\Black Mirror"', u'-nowindow']
pythonw.exe INFO:EmberMediaManager:TV Show Black Mirror already on kodi's library. Scan folder for new episode.
pythonw.exe INFO:EmberMediaManager:Sonarr Ember Media Manager post-processing script started.
EDIT: while browsing my EMM log I saw this error at the same timestamp as previous python script:
2019-06-05 10:22:13.4798;Ember_Media_Manager.My.MyApplication;Ember_Media_Manager.My.MyApplication.MyApplication_Startup;1;INFO;====Ember Media Manager starting up====;
2019-06-05 10:22:13.5678;Ember_Media_Manager.My.MyApplication;Ember_Media_Manager.My.MyApplication.MyApplication_Startup;1;INFO;====Version 1.4.90 x64;
2019-06-05 10:22:19.7072;EmberAPI.Database;EmberAPI.Database.Connect_MyVideos;1;ERROR;Connect_MyVideos    Unable to open media database connection.;"EXCEPTION OCCURRED:System.DllNotFoundException: Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
   at System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(SQLiteConfigOpsEnum op)
   at System.Data.SQLite.SQLite3.StaticIsInitialized()
   at System.Data.SQLite.SQLiteLog.Initialize()
   at System.Data.SQLite.SQLiteConnection..ctor(String connectionString, Boolean parseViaFramework)
   at EmberAPI.Database.Connect_MyVideos()*   at System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(SQLiteConfigOpsEnum op)
   at EmberAPI.Database.Connect_MyVideos()"
2019-06-05 10:22:19.7322;Ember_Media_Manager.My.MyApplication;Ember_Media_Manager.My.MyApplication.MyApplication_UnhandledException;1;ERROR;EmberAPI;"EXCEPTION OCCURRED:System.NullReferenceException: Object reference not set to an instance of an object.
   at EmberAPI.Database.LoadAllGenres()
   at Ember_Media_Manager.frmMain.frmMain_Load(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)*   at EmberAPI.Database.LoadAllGenres()
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)"
Could this be the culprit?
Finaly!
Googled a bit the problem and ended up copying
SQLite.Interop.dll
from x64 folder to EMM root folder where the
is placed.
All is working now.
Don't understand why it worked for movies scraping but it is working now Smile
@redglory that issue has been around for about a year, not just a python problem https://forum.kodi.tv/showthread.php?tid...pid2732437
Ok thx.
Works for now
That's strange, all DLL's will be indexed manually at the start and before the command line will be exequeted. I'ill check that, bug has been added to the tracker: Link
(2019-06-07, 09:30)DanCooper Wrote: [ -> ]That's strange, all DLL's will be indexed manually at the start and before the command line will be exequeted. I'ill check that, bug has been added to the tracker: Link
I'm having same problem and I already have the file on the root of EmberMediaManager.exe
This only happens for tv shows...
I had to call my script using powershell script as on latest Sonarr version you can't no longer pass arguments...
python:
python2w C:\ProgramData\Sonarr\scripts\EmberMediaManager\main.py
I can't even get anything on EMM logs.
If I run my script directly on powershell it calls it without a problem.
Ran again with same error on Sonarr log file:
python:
powershell.exe at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
powershell.exe at System.Windows.Forms.Control.WndProcException(Exception e)
powershell.exe at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
powershell.exe at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnUnhandledException(UnhandledExceptionEventArgs e)
powershell.exe at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.raise_UnhandledException(Object sender, UnhandledExceptionEventArgs e)
powershell.exe at Ember_Media_Manager.My.MyApplication.MyApplication_UnhandledException(Object sender, UnhandledExceptionEventArgs e)
powershell.exe at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
powershell.exe Unhandled Exception: System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
powershell.exe ERROR:EmberMediaManager:Ember Media Manager failed with: -1073740771
powershell.exe INFO:EmberMediaManager:Ember Media Manager: running on PID: (15192)
powershell.exe INFO:EmberMediaManager:TV Show Internal ID: 149
powershell.exe INFO:EmberMediaManager:TV Show TVDB ID: 366026
powershell.exe INFO:EmberMediaManager:TV Show Full Path: T:\TV\Typewriter
powershell.exe INFO:EmberMediaManager:TV Show Title: Typewriter
powershell.exe INFO:EmberMediaManager:Starting Ember Media Manager with application arguments: ['C:\\ProgramData\\EmberMediaManager\\Ember Media Manager.exe', u'-profile', u'redglory', u'-scanfolder', u'"T:\\TV\\Typewriter"', u'-nowindow']
powershell.exe INFO:EmberMediaManager:TV Show Typewriter already on kodi's library. Scan folder for new episode.
powershell.exe INFO:EmberMediaManager:Sonarr Ember Media Manager post-processing script started.
My application folder
I've ended up creating executable python script and call it on Sonarr (created it with options: -w (No Console) -F (Onefile).
It works like a charm
hey all,
I'm trying to work out the commandline switches to rescrape the thumb and nfo for a single episode only, but just cannot get it working.
I would like add automation into my daily script where I can tell Ember to rescrape episodes with missing thumb, plot, rating etc.
I'm hoping to extract strFilePath from SQLite into a text file, adding the correct switches.
has anyone done this before?
thanks Smile
(2021-05-25, 16:23)zerocool_ie Wrote: [ -> ]hey all,
thanks Smile
I don't think you can scrape a single episode. But better ask @DanCooper
(2021-05-25, 16:23)zerocool_ie Wrote: [ -> ]I'm trying to work out the commandline switches to rescrape the thumb and nfo for a single episode only, but just cannot get it working.
It's not possible.
But I could add that if you specify a path to a movie/tvshow/episode, only that path will be scrapped. For example (same for all other types):
-scrapemovies [ScrapeType] single "D:\Movie\Avatar\Avatar.mkv" [ScrapeModifier]
Would that help?
For Ember 3.0 i've planned to implement a JSON interface like in Kodi to get the ID of a video to modify/scrape/whatever a video with this ID like you whould do in the GUI. But that takes time Big Grin
(2021-05-27, 01:21)DanCooper Wrote: [ -> ]
It's not possible.
Would that help?
thanks @redglory & @DanCooper
That option would be great to have at some point down the line - I'm sure there are more important features you are working on Smile
Hi, this most likely happens because it is trying to show some modal windows and since you don't have gui it breaks.
