2006-10-29, 22:28
I've searched... really I have. I have had other issues resolved by serching and everything has been great, so please... if I missed my answer on this one, I am truly sorry.
I am using Creatives Digital VCR program to record my TV programs. It comes bundled with a converter to make it;s propritary video files mpeg-2 files.
When I stream these mepg-2 files to XBMC via smb, I get no audio, crisp clean wonderful video, but no audio.
I would assume there is an issue with the audio codec, my log file says so (you can see for yourself below) but I DO NOT know exactly how the Creative converter encodes the audio.
If I load the Creative mpg file into say, Nero, and export it out as an mpg file... I get audio and video, no trouble... except that it;s the second time to convert the file and genarally takes a long time to do so.
Am I just screwed using Creative, or is there some new codec I don;t have?
Oh yeah... I am using the August 29th build of XBMC on a softmoded box... And the same issue occurs whether streaming, or if the file has been ftp'ed and played form the Xbox hdd.
Thanks guys!
-Jeremy
Log file follows (network identifiers deleted for secruity purposes)
Sorry it's not from boot to end of playback, that was too many characters, hoefully this is enough for you!
12:15:03 M: 39272448 DEBUG: CPlayerCoreFactor::GetPlayers(smb://****/mpg/Untitled (SP) 4544dfca.mpg)
12:15:03 M: 38748160 INFO: mplayer play:smb://****/mpg/Untitled (SP) 4544dfca.mpg cachesize:2048
12:15:03 M: 38748160 DEBUG: DIRECTORY::CSMBDirectory::OpenDir - Using authentication url smb://****/mpg
12:15:03 M: 32378880 DEBUG: msg: set audio functions called
12:15:03 M: 32378880 DEBUG: msg: done
12:15:03 M: 32378880 INFO: Using -subcp enca:__:CP1252 to detect the subtitle charset
12:15:03 M: 32378880 INFO: Flipping bi-directional subtitles disabled
12:15:03 M: 32378880 DEBUG: msg: mplayer_init()
12:15:03 M: 32378880 DEBUG: msg: enable mplayer osd
12:15:03 M: 32378880 DEBUG: msg: MPlayer dev-CVS-060924-20:59 © 2000-2004 MPlayer Team
12:15:03 M: 32378880 DEBUG: msg: CPU: Intel Celeron 2/Pentium III Coppermine,Geyserville
12:15:03 M: 32378880 DEBUG: msg: (Family: 6, Stepping: 10)
12:15:03 M: 32378880 DEBUG: msg: Detected cache-line size is 32 bytes
12:15:03 M: 32378880 DEBUG: msg: CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
12:15:03 M: 32378880 DEBUG: msg: Compiled for x86 CPU with extensions:
12:15:03 M: 32378880 DEBUG: msg: MMX
12:15:03 M: 32378880 DEBUG: msg: MMX2
12:15:03 M: 32378880 DEBUG: msg: SSE
12:15:03 M: 32366592 DEBUG: msg:
12:15:03 M: 32374784 DEBUG: msg: Creating config file: Q:\system\players\mplayer\config
12:15:03 M: 32362496 DEBUG: msg:
12:15:03 M: 32079872 DEBUG: msg: 88 audio & 199 video codecs
12:15:03 M: 32043008 DEBUG: msg: mplayer_open_file(smb://****/mpg/Untitled (SP) 4544dfca.mpg)
12:15:03 M: 32043008 INFO: Stating file smb://****/mpg/Untitled (SP) 4544dfca.mpg.conf
12:15:03 M: 32043008 INFO: Stating file Q:\system\players\mplayer\Untitled (SP) 4544dfca.mpg.conf
12:15:03 M: 32043008 DEBUG: msg: Playing smb://****/mpg/Untitled (SP) 4544dfca.mpg.
12:15:03 M: 32043008 DEBUG: msg: find subtitles
12:15:03 M: 32043008 DEBUG: msg: auto open Z:\subtitle
12:15:03 M: 32043008 DEBUG: msg: protocol:smb
12:15:03 M: 32043008 DEBUG: msg: use standard file for protocol:smb
12:15:03 M: 32043008 DEBUG: msg: Option stream url: This URL doesn't have a hostname part.
12:15:03 M: 29372416 DEBUG: msg:
Cache fill: 0.00% (0 bytes)
Cache fill: 12.50% (262144 bytes)
12:15:03 M: 29372416 DEBUG: msg: demux_open(00BE4010,0,-1,-1,-1)
12:15:03 M: 29327360 DEBUG: msg: MPEG-PS file format detected.
12:15:03 M: 28274688 DEBUG: msg: VIDEO: MPEG2 640x480 (aspect 2) 29.970 fps 10000.0 kbps (1250.0 kbyte/s)
12:15:03 M: 28274688 DEBUG: msg: Starting lookup for subs
12:15:03 M: 28274688 DEBUG: msg: Global Subsize: 0 - VOBSUB: -1, DEMUX: -1, SUBS: -1
12:15:03 M: 28274688 DEBUG: msg: Global Subpos : -1
12:15:03 M: 28274688 DEBUG: msg: ==========================================================================
12:15:03 M: 28274688 DEBUG: msg: Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
12:15:04 M: 22245376 DEBUG: msg: ADecoder init failed :(
12:15:04 M: 22323200 DEBUG: msg: ADecoder init failed :(
12:15:04 M: 22323200 DEBUG: msg: Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
12:15:04 M: 21913600 DEBUG: msg: Unknown/missing audio format -> no sound
12:15:04 M: 22130688 DEBUG: msg: ADecoder init failed :(
12:15:04 M: 22130688 DEBUG: msg: Requested audio codec family [mad] (afm=libmad) not available.
Enable it at compilation.
12:15:04 M: 22130688 DEBUG: msg: Cannot find codec for audio format 0x50.
12:15:04 M: 22130688 DEBUG: msg: Read DOCS/HTML/en/codecs.html!
12:15:04 M: 22130688 DEBUG: msg: ==========================================================================
12:15:04 M: 22130688 DEBUG: CXBoxRenderManager::PreInit - Selected RGB-Renderer
12:15:04 M: 21622784 DEBUG: msg: ==========================================================================
12:15:04 M: 21622784 DEBUG: msg: Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
12:15:04 M: 21622784 DEBUG: msg: VDec: vo config request - 640 x 480 (preferred csp: Mpeg PES)
12:15:04 M: 21622784 DEBUG: msg: Could not find matching colorspace - retrying with -vf scale...
12:15:04 M: 21622784 DEBUG: msg: Opening video filter: [scale]
12:15:04 M: 21622784 DEBUG: msg: The selected video_out device is incompatible with this codec.
12:15:04 M: 21622784 DEBUG: msg: VDecoder init failed :(
12:15:04 M: 21622784 DEBUG: msg: Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
12:15:04 M: 20369408 DEBUG: msg: Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG-1 or 2 (libmpeg2))
12:15:04 M: 20369408 DEBUG: msg: ==========================================================================
12:15:04 M: 20369408 DEBUG: msg: Audio: no sound
12:15:04 M: 20369408 DEBUG: msg: Starting playback...
12:15:04 M: 20369408 DEBUG: msg: mplayer_open_file(smb://****/mpg/Untitled (SP) 4544dfca.mpg) done 1.0000
12:15:04 M: 19845120 DEBUG: Playback has started
12:15:04 M: 19886080 DEBUG: msg: VDec: vo config request - 640 x 480 (preferred csp: Planar YV12)
12:15:04 M: 19886080 DEBUG: msg: VDec: using Planar YV12 as output csp (no 0)
12:15:04 M: 20410368 DEBUG: msg: Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
12:15:04 M: 20410368 DEBUG: msg: VO: [directx] 640x480 => 640x480 Planar YV12
12:15:04 M: 20410368 NOTICE: Display resolution AUTO : NTSC 4:3 (4)
12:15:04 M: 19918848 DEBUG: Created YV12 texture 0
12:15:04 M: 19427328 DEBUG: Created YV12 texture 1
12:15:04 M: 18964480 DEBUG: Activating window ID: 12005
12:15:04 M: 18964480 DEBUG: Checking if window ID 12005 is locked.
12:15:04 M: 24035328 DEBUG: Deleted YV12 texture 1
12:15:04 M: 24035328 INFO: Loading skin file: VideoFullscreen.xml
12:15:04 M: 24035328 INFO: Loading skin file: VideoOSD.xml
12:15:04 M: 23437312 INFO: Loading skin file: VideoOSDSettings.xml
12:15:04 M: 22728704 INFO: Loading skin file: VideoOSDSettings.xml
12:15:05 M: 22269952 DEBUG: CGUIFontTTF::Load Scaled size of font Q:\Media\Fonts\Arial.ttf (28): width = 76, height = 39
12:15:05 M: 21778432 DEBUG: msg: FFRW:normal play
12:15:05 M: 21774336 DEBUG: CGUIInfoManager::SetCurrentMovie(smb://****/mpg/Untitled (SP) 4544dfca.mpg)
12:15:05 M: 20807680 DEBUG: CVideoDatabase::GetMovieInfo(smb://****/mpg/Untitled (SP) 4544dfca.mpg), query = select * from movie join path on movie.idPath = path.idPath join movieinfo on movie.idMovie = movieinfo.idMovie join files on movie.idMovie = files.idMovie where (path.strPath like 'smb://****/mpg' and files.strFileName like '/Untitled (SP) 4544dfca.mpg') or path.strPath like 'stack://smb://****/mpg'
12:15:16 M: 26505216 DEBUG: msg: mplayer_close_file()
12:15:16 M: 26603520 DEBUG: msg:
12:15:16 M: 26603520 DEBUG: msg: uninit_player
12:15:16 M: 33447936 DEBUG: Deleted YV12 texture 0
12:15:16 M: 33697792 DEBUG: msg: uninit_player - done
12:15:16 M: 33697792 DEBUG: Freeing FS segment @ 0xa835c0
12:15:16 M: 33697792 DEBUG: Playback has finished
Thanks guys!
-Jeremy
