(2017-12-30, 15:31)Skank Wrote: [ -> ] (2017-12-30, 15:26)Maxmueller Wrote: [ -> ] (2017-12-30, 15:21)Skank Wrote: [ -> ]Can you share your version pls?
look post #391 and download.
ok will do thx
there are so may grafik issues in this version. install it and test it. my version runs now nearly perfect. i share my changed files with you if you like.cheers
(2017-12-30, 15:35)Maxmueller Wrote: [ -> ] (2017-12-30, 15:31)Skank Wrote: [ -> ] (2017-12-30, 15:26)Maxmueller Wrote: [ -> ]look post #391 and download.
ok will do thx
Then i better test your version straight away no?
Yes pls share
ok will do thx
hoerah
that version works
so your version with fixes will work too, can you share please
some questions
is there a skin export and import ability?
if i chose wall view, can i change the amount of items ?
for widgets can i change the amount of widgets too?
still willing to share your version
(2017-12-30, 17:26)Skank Wrote: [ -> ] hoerah
that version works
some questions
Hi Skank,
you must install the scopenox Krypthon skin.
Then you can download my files from
https://www.dropbox.com/s/0kztt3e9g7wb3y...t.zip?dl=0
You must copy all my files to the original scopeformat folder in your instalation.
greetings
(2017-12-30, 19:25)Maxmueller Wrote: [ -> ] (2017-12-30, 17:26)Skank Wrote: [ -> ] hoerah
that version works
some questions
Hi Skank,
You must copie all my files to the original scopeformat folder in your instalation.
greetings
Ok thx, will try tomorrow
Any idea how i get 2 lines of covers in the "wall view"
(2017-12-30, 21:19)Skank Wrote: [ -> ]Ok thx, will try tomorrow
no, there is no funktion to set the numbers of lines and covers.
i´m not a real skinning freak and my skill is basic on programming.
you like "wall view" with 2 lines and 7 covers?
(2017-12-30, 23:39)Skank Wrote: [ -> ] (2017-12-30, 21:34)Maxmueller Wrote: [ -> ] (2017-12-30, 21:19)Skank Wrote: [ -> ]Ok thx, will try tomorrow
Yes i do
ok, i make for you a "wall" view with 2 lines and 7 covers .
you must wait a moment. i post a downloadlink tomorrow.
do my changes work on your system?
Just downloaded your dropbox file
Where can i see if your files work? point me to a fix
Cool you will do the wall view for me, thx mate !
Happy new year @all.
Skank
you are familar with exchange files in your kodi instalation ??
many issues in the original Skin from funkd are grafics in the wrong place. so covers are cutted with the black bars on top or buttom.
The Weathergrafics most in the wrong place or fully invisible.
You must exchange the files in the "scopeformat" folder with my files. Then most grafics are on the right place.
My instalation is good for Weather, Music, Video, Movie, TV Show and Settings section.
For you or other i had made the wall View with 2 Rows and 7 Covers each row. InfoPanel works great.
You can download here:
https://www.dropbox.com/s/94i2eungzxpsa6...l.xml?dl=0
Thx, yes i did exchange them! Thx
Any idea for the subtitles, see other thread
(2018-01-01, 14:43)Skank Wrote: [ -> ]Thx, yes i did exchange them! Thx
no, i use the original kodi subtitle funktion an this works for me.
test all settings.
for tv shows in 16:9 i zoom the picture with kodi to 0,76, this fits on my screen and i mask my screen left and right.
do you have a windows media pc, a raspberry or another mediaplayer?
(2018-01-01, 15:19)Maxmueller Wrote: [ -> ] (2018-01-01, 14:43)Skank Wrote: [ -> ]Thx, yes i did exchange them! Thx
test all settings.
I use windows intel nuc withafedchin build.
Your projector is 16:9 right?
So you dont zoom with your projector?
Can you tell me how you set it up?
I zoom my projector so it fills my 2:39 screen. Then i start kodi and i use mask from skin when watching 16:9 content, you dont do this?
You do it differently?
You got subs at "fixed" right?
