Full Version: Getting channel logos
Hey there,
I'd like to get the channels of my kodi setup and present the logos of each channel on a web interface. So I'm basically calling:
PHP Code:
{"jsonrpc""2.0""method""PVR.GetChannels""params": {"channelgroupid" :2,"properties":["channel","channeltype","thumbnail","broadcastnow","broadcastnext"]]}
And I receive the thumbnails as below:
Quote:"thumbnail": "image://%2fhome%2farch%2flogos%2fenen%2flogos%2frtp1.png/"
Does anyone know how can I use this logo on a webpage? I assume there is some method to serve the path above through http?
I just get lost on the documentation. By inspecting other apps I can't find out any other call appart to the one I posted above.
Thanks in advance
It seems that according to: http://kodi.wiki/view/Webserver
The image should be called this way:
http://<your ip>:<configured port>/image/<url encoded image:// path>
Just for reference, what I was trying to do was to present the logos of my own channels on a webpage. So basically, any json-rpc command would be executed from python (from kodi itself), without knowing anything about the webserver setup. This placed a problem because the json api returns a thumbnail value that can only be retrieved if passed to the webserver. Since the python addon doesn't know anything about the webserver (user,pass,port,etc) it's a no go.
So my solution was to find out first the settings of the webserver by calling getsettings:
PHP Code:
import xbmc,json
#small hack to grab webserver endpoint for texture conversion
webserver_ipaddr xbmc.getIPAddress()
webserver_port ''
webserver_username ''
webserver_password ''
webserver_isenabled False
json_response
xbmc.executeJSONRPC('{"jsonrpc":"2.0","method":"Settings.GetSettings","params":{"level":"expert"},"id":25}')
decoded_data json.loads(json_response)
for
setting in decoded_data["result"]["settings"]:
    if
setting["id"] == "services.webserver"webserver_isenabled setting["value"]
    if
setting["id"] == "services.webserverport"webserver_port setting["value"
    if
setting["id"] == "services.webserverusername"webserver_username setting["value"
    if
setting["id"] == "services.webserverpassword"webserver_password setting["value"
if
webserver_isenabled:
    if
webserver_password == '':
webserver 'http://'+webserver_ipaddr+':'+str(webserver_port)+'/image/'
else:
webserver 'http://'+webserver_username+':'+webserver_password+'@'+webserver_ipaddr+':'+str(webserver_port)+'/image/'
else:
webserver ""
#Now we have a callable webserver url, get all the logos for groupid 2
json_response xbmc.executeJSONRPC('{"jsonrpc": "2.0", "method": "PVR.GetChannels", "params": {"channelgroupid" : 2,"properties":["channel","channeltype","thumbnail","broadcastnow","broadcastnext"]}, "id": 1 }')
tvchannel_dict = {}
for
channel in decoded_data["result"]["channels"]:
    try:
        if
webserver != ''tvchannel_dict['thumb'] = webserver urllib.quote(channel["thumbnail"])
        else:
tvchannel_dict['thumb'] = ""
excepttvchannel_dict['thumb'] = ""
Marked as solved.
