2006-10-31, 18:05
This is not a XBMC issue but rather a Windows xp home edition problem ?
I thought that I would like to see if anyone else has this problem and hence have a solution.
APOLOGISES in advance.
Is it just me ? :mad:
- Let's say you have a USB hard disk which contains the movies you want to watch in XMBC
- Then you share it (RIGHT CLICK the hard disk > SHARING and SECURITY > and then set the hard disk to be sharing)
- So now your USB hard disk is available for sharing over the network and hence XBMC can see it and you can watch your movies
- Now reboot
- The sharing folder is now gone from the USB drive. The drive is not longer sharing again ! You nee to re-do the SHARING process again every time you reboot !
