I am wanting to try some skinning and came across the addon "Skin Foundation" which was created a couple of years ago for beginners. when I try to install from the .zip file I get the message that it does not meet dependencies. Can someone help to resolve the issue please? I thank you in advance for your help.
that skin is pretty outdated.
if you're desperate to install it, just manually unzip the skin in your addons folder.
Thank you Ronie. I will try that. Failing that is there another way to try my hand at skinning? I have a few ideas of what I want in a skin and want to give them a go.
Thanks again.
(2015-06-15, 04:01)XBMCPCTV Wrote: [ -> ]Thank you Ronie. I will try that. Failing that is there another way to try my hand at skinning? I have a few ideas of what I want in a skin and want to give them a go.
Thanks again.
Confluence is very basic. Just take that one + read the
Skinning Manual (wiki).
Thank you phil65. I have briefly looked at the skinning manual. It all seems a bit much to take in at first glance. I am assuming that
when I go into the Confluence skin, I go to the 720p file and systematically edit each .xml file in there.
Thanks again.
