Full Version: Streaming Kodi through Miracast
Hy,
I´va a tronsmart S82 running with Kodi 14.2. Now I´d like to stream from one room to another from der S82 with a miracast dongle.
It is possible that is to operate separately from 2 different locations?
Thanks in advance for your reply.
You could use a smartphone/tablet remote app to control Kodi (or even the whole Android box, IIRC).
so can i use the wifi direct acces from the one miracast to the other one to acces kodi on the box.
Do you know an app from the store?
If it's possible or not to actually cast depends on the device itself, if it supports transmitting/mirroring via miracast.
Thanks for your reply. Do you know a good device, maybe Chromecast?
At the price of a Chromecast, you might as well get something like a Fire TV stick and just have two Kodi installs.
A chromecast costs 20€, a MK809 costs 35€. But the advantage is, that you can move the MK to any place you want Big Grin.
Ok thanks a lot for your time.
