Full Version: Kodi 15.0 Isengard – Beta 2 SMB Crash Nexus Player
Just updated to Kodi 15.0 Isengard – Beta 2
and it crashes on nexus player when I try to access my files on smb.
It only happens on nexus player.
when I play files on smb from my nexus 5 or nexus 7 it works just fine.
Only nexus player has the problem when playing from smb it crashes right after I select my hard drive which was already added from previous version.
It also crashes when I go to add videos then browse then select smb or when I enter path manually it will crash when I click ok after entering the correct path.
If I enter wrong path it does not crash and just says the unable to retrieve directory information would you like to add anyway?
http://xbmclogs.com/ptkdw1rau#line-6
this log was when it crashed going to add videos then browse then selecting smb
ive tried this on my nexus 5 and 7 and there are no issues there
still have my smb folder already setup for those devices from previous version and they play without issue after updating
can you install the ARM version from http://kodi.tv/download/ ?
I did not try, I just went back to beta 1 since I didn't have much problems with that one
I did a fresh install and it seemed to have fixed it,
another person had to clear app data and it stopped crashing for them
