2015-06-15, 18:43
2015-06-15, 18:44
I dont understand what you mean. More details, please. (Screenshots can help)
2015-06-15, 19:02
Im just getting round to updating a stripped down version of confluence that runs on a Rpi in the kitchen, because the parents use it as well i included a description label at the bottom that told them what each icon did when it was focused.
I used to use a custom window & view etc.. & for visibility of the description for each focused item i used eg. <visible>Container(5000).Hasfocus(2)</visible>
Im now updating to use the music library nodes instead, but <visible>Container(5000).Hasfocus(2)</visible> doesn't work in the library window.
How do i now set visibility when a item is focused in the music library?
2015-06-15, 19:02
if it's about the root listing in the music library, you can do a stringcompare on ListItem.FolderPath.
<visible>StringCompare(ListItem.FolderPath,library://music/genres.xml/)</visible>
2015-06-15, 19:05
Perfect!
Thanks Ronie
Thanks Ronie
