Hmm--tried posting this yesterday, but it seems to have not worked:
I'm having some problems with the mythtv front-end.
MythTV machine name is "gibreel", IP 192.168.15.180
Set up my source in XBMC as myth://mythtv:
[email protected]/ and I can access the list of recordings. I can even see the thumbnails--just can't play anything. I select a video and it sits there for about 30 seconds and does nothing. If I go in and navigate via SMB to the mythtv box's recordings directory, they play fine. Just not through the mythtv recordings interface. Might I have misconfigured something? I have DNS set up properly so I doubt it's that.
I believe I have the latest T3CH build of XBMC:
20:34:19 M: 57573376 NOTICE: Starting XBMC, Platform: Xbox. Built on Jun 30 2008
20:34:19 M: 57573376 NOTICE: Q is mapped to: E:\dashboard
20:34:19 M: 57573376 NOTICE: The executeable running is: E:\dashboard\default.xbe
20:34:19 M: 57573376 NOTICE: Log File is located: Q:\xbmc.log
Here's the debug log:
21:10:41 M: 35962880 DEBUG: CPlayerCoreFactor::GetPlayers(myth://mythtv:
[email protected]/recordings/1036_20080816210000.mpg)
21:10:41 M: 35962880 NOTICE: DVDPlayer: Opening: myth://mythtv:
21:10:41 M: 35962880 WARNING: CDVDMessageQueue:
ut MSGQ_NOT_INITIALIZED
21:10:41 M: 35438592 NOTICE: Creating InputStream
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll GetFileAttributesExA
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll SetNamedPipeHandleState
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll WaitNamedPipeA
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll UnmapViewOfFile
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll MapViewOfFile
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll OpenFileMappingA
21:10:41 M: 33939456 DEBUG: Unable to resolve kernel32.dll OpenEventA
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll ?terminate@@YAXXZ
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll __doserrno
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll _open_osfhandle
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll _umask
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll ldiv
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll iscntrl
21:10:41 M: 33939456 DEBUG: Unable to resolve msvcr71.dll ??1type_info@@UAE@XZ
21:10:41 M: 33939456 DEBUG: kernel32.dll fake function DisableThreadLibraryCalls called
21:10:41 M: 33918976 INFO: msg: (cmyth)
21:10:41 M: 33923072 INFO: msg: cmyth_conn_connect: asked for version 8, got version 40
21:10:41 M: 33923072 INFO: msg: cmyth_conn_connect: asked for version 40, got version 40
21:10:41 M: 33923072 INFO: msg: (cmyth)
21:10:41 M: 33923072 INFO: msg: __cmyth_rcv_proginfo: got recording info
21:10:42 M: 33837056 DEBUG: Got rss feed:
http://feeds.feedburner.com/XboxScene
21:10:42 M: 33845248 DEBUG: RSS feed encoding: UTF-8
21:10:42 M: 33845248 DEBUG: Parsed rss feed:
21:10:43 M: 34004992 INFO: Loading skin file: DialogBusy.xml
21:10:43 M: 34009088 DEBUG: Load DialogBusy.xml: 29.09ms (21.42 ms xml load)
21:10:43 M: 34009088 DEBUG: Alloc resources: 29.54ms (29.54 ms skin load, 0.00 ms preload)
21:11:01 M: 33869824 INFO: msg: (cmyth)
21:11:01 M: 33869824 INFO: msg: cmyth_connect: connect failed on port 6543 to 'gibreel' (10060)
21:11:01 M: 33869824 INFO: msg: cmyth_conn_connect_file: cmyth_connect(gibreel, 6543, 16384) failed
21:11:01 M: 33869824 INFO: msg: cmyth_file_destroy: cmyth_rcv_okay() failed (-1)
21:11:01 M: 33869824 ERROR: XFILE::CCMythFile::SetupRecording - unable to connect to file
21:11:01 M: 33869824 ERROR: InputStream: Error opening, myth://mythtv:
21:11:01 M: 33869824 NOTICE: CDVDPlayer::OnExit()
21:11:01 M: 33869824 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:11:06 M: 34553856 INFO: XFILE::CCMythSession::CheckIdle - Closing idle connection to mythtv backend 192.168.15.180
21:11:36 M: 34566144 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\libcmyth.dll)
21:11:36 M: 34566144 DEBUG: Q:\system\libcmyth.dll (base 10000000): Detected memory leaks: 1 leaks
21:11:36 M: 34566144 DEBUG: leak caller address 10001022, size 14, counter 1
21:11:36 M: 34566144 DEBUG: libcmyth.dll: Total bytes leaked: 14
