I'm trying to make the movie-label expend to two lines if needs so, but wrapmultiline=true inside the "label" control doesnt effect.
tried with textbox control and it is working. (the control is inside the <itemlayout> group)
and one more thing, there is any way to recognize how many lines the "textbox"\"label" has? like I want to show movie-genre under the movie-title only if movie-title has one line, if two - don't show the Genre.
(2015-06-16, 10:41)tomer953 Wrote: [ -> ]I'm trying to make the movie-label expend to two lines if needs so, but wrapmultiline=true inside the "label" control doesnt effect.
I think wrapmultiline for labels in containers doesn't work since a long time or maybe never worked. Had the same issue and found some thread speaking about it. For textbox / wrapmultiline, as far as I know, there no solutions to count the lines.
ok thanks.
I gave up, used 1 line with autoscroll and thats it.
just a little bug report to developers, when using RTL language (Arabic,Hebrew), and the width of the label is short, then the label is cut off from the wrong side....
for example:
"50 shades of grey" will be like:
"....des of grey"
also the scroll direction is in the wrong direction (to the left and not to the right)
I would very happy to see the option to set scroll direction, and to set which side of the label get cut when "width" is not wide enough.
