Full Version: OSD problem on Isengard
I just installed OpenELEC 6.0 beta 2 (based on Isengard beta 2) on my rPi 2.
While playing a video and bringing up any OSD elements such as volume, channel list, info dialogue, the video will pause/stutter for an instant. It only happens if you bring up a different OSD element each time. It does not happen on Confluence, or the OSMC skin, which appears to be very similar to Conq.
It happens regardless of video format, and regardless of the "limit GUI updates" setting.
I'm running latest versions of Conq and OSMC from github, and this is a clean install. Any ideas? I would use the OSMC skin since it does not exhibit this problem, but I prefer a horizontal menu so would like to stick with Conq.
