Is there a way to export the thumb and fanart for my movie sets and import it on a second machine? I have hundreds of movies in the library and it'll be quite a hassle to change each one manually.
I'm using 14.2 on both machines.
Thanks, but I actually already tried that. It didn't pick up any of the artwork with my existing file names and having to rename every single file is not going to be any more convenient than just importing manually from within Kodi.
To be honest, I was kind of hoping that it was something simple that I'd missed. It seems odd to me, now that movie sets are officially supported, that they're not included in the exported library.
Having the same problem. Rather than redirecting us to an add-on, it would be very much appreciated if, just the same way the art for movies is exported with the library, it was included such export option for sets... since one could have custom sets all over the library mixed with scraped sets. So that importing back would not destroy all the hard work in organizing sets.
