I recently upgraded to Aeon Nox 5 from Aeon Nox 4 but for some reason the episode viewtype for movies and tv shows is not showing up, I see it in the Aeon Nox 5 folder but I can't select it in Kodi, any help would be appreciated thanks.
I believe it's only available for episodes in Nox 5. Have you tried selecting it at the Episode level?
Hrmm so the viewtype doesn't work in Nox 5 that's weird, I'll just stick with Nox 4 then, although the search and rename function doesn't work. Does anyone know why it's in the Aeon Nox 5 folder but not selectable in Kodi, is there a way to activate it or am I just out of luck here!?
It works but it's designed for episodes only, hence the viewtype name.
No, the episode viewtype works in Aeon Nox 4 for movies as well as tv shows, so you must be referring to something different then what I'm asking. I'm guessing what I'm asking isn't possible, it's weird that Aeon Nox 4 has this viewtype and Aeon Nox 5 does not, thanks anyway.
