When adjusting volume, there's 2 volume indicator...1st is a long slider @ the bottom of the screen and the 2nd is @ top right side of the screen. The question is how to disable 1 of them, doesn't matter which one.
Thnx
Guessing this might be way down on the developer's To Do List... I'm rather sure one belongs to Android/firmware(the top center one in my case, as it appears when volume is adjusted on the android box while on the android launcher) and the other in the upper right to KODI, but it's probably a bugger to fix, or someone has a hack for it, or no one who can actually fix it cares enough about the "non-issue" to be bothered. As KODI is a community supported project not a commercial one most people would expect minor preference issues like that to be gotten around to when the Developers run out of real issues that affect the operation of KODI or ideas for new features. Good luck, but don't hold your breath, you'll just turn bluish, pass out and have to start all over... ;-)
By the way, how about a hand all around for the crazy, screwball, selfless, doing-it-all-for-free, cause-they-can developers/contributors that have made KODI what it is!
Not only a given them round of applause also monetary and lots of gratitude's..
