Full Version: Livestream
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
(2015-06-30, 17:07)eracknaphobia Wrote: [ -> ]
(2015-06-29, 20:51)eracknaphobia Wrote: [ -> ]
(2015-06-29, 13:20)harpua1982 Wrote: [ -> ]Awesome addon. Thanks a bunch! I'm able to search for streams but not for LiveStream Users. Any chances of that happening?
It should search accounts too. Is there a particular one that is giving you trouble?
And I did some digging and it does search users, but if there are no live streams for that particular user it won't display any streams which kinda makes sense. I'll see if I can work something out with displaying archived video.
The user that I was searching for wouldn't come up in a search at the time, but the live stream was for some reason. The user has since deleted his acct. I need to do more research w/ this addon and service, though. Thanks for your contribution.
This,
http://livestream.com/accounts/11327981/events/3653563, for example, is a local news channel that I'm following on LS. I am unable to search and find the channel (probably b/c the channel is simply labeled, "Live") through the addon, but I am in the LS app.
(2015-07-07, 13:38)harpua1982 Wrote: [ -> ]This,
When I search for "WIS" on the web page I don't see it in the results. This is why the addon doesn't work, it runs the same command.
Hi
Just wanted to say thanks for this addon.
I set it up a week or so back but got to use it last night to watch a game of Rugby League (from the NRL Channel)
Finding it was a little tricky but once I found the game it played flawlessly! (and with out the ads that interrupt the browser stream!)
Thanks again
Justin
Great, thanks.
I tried to find this one...
https://livestream.com/news/KTLA
without any luck. I browsed and searched. Any ideas?
Thanx...
So, if I have Kodi on an Amazon Fire, how do I install this? I can't find it in the list of addons OR by search.
(2015-07-27, 00:46)JamieLynn Wrote: [ -> ]So, if I have Kodi on an Amazon Fire, how do I install this? I can't find it in the list of addons OR by search.
http://kodi.wiki/view/HOW-TO:Install_add..._zip_files
oooh, great. was looking for a way to get the mma hour on kodi.
Version 2015.8.13 is great Smile
Development suggestion:
How about a search menu that saves.. say 10 latest search terms.
And with ability to clear old search terms too.
Some one in an earlier post mentioned a username and password......are they required to use this ?
(2015-08-18, 18:25)wardio666 Wrote: [ -> ]Some one in an earlier post mentioned a username and password......are they required to use this ?
No. It is optional.
Username/pass is for maintaining your favorites/bookmarks etc just like Youtube
(2015-08-18, 18:41)siuside Wrote: [ -> ]
No. It is optional.
roger!, thanks!
Sad Not working on my kodi m8 android box? I installed the file and got to the addon but when I search live and upcoming I get a script failed error, any help/suggestions would be much appreciated
Many thanks
Not sure. I just tested the addon briefly and all the sections seem to be working. Is there a specific word you were searching that is giving you an error or were you just selecting Live & Upcoming? Either way a log file would help us find a cause here.
http://kodi.wiki/view/Log_file/Easy
