Full Version: Livestream
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Thanks for this addon. I have the following problem though, I am trying to get http://livestream.com/accounts/14486838/canalantigua, but the addon return the video which is in: http://livestream.com/accounts/14486838/...s/96310225.
Full log in: http://pastebin.com/mEif3q9t
(2015-08-27, 11:07)nikki7luc Wrote: [ -> ]Sad Not working on my kodi m8 android box? I installed the file and got to the addon but when I search live and upcoming I get a script failed error, any help/suggestions would be much appreciated
Many thanks
I am getting the exact same thing happening to me on Openelec. I have the plugin installed on my windows pc running Kodi and it works just fine but I just tried to install it on two separate machines running openelec and I got "Script Failed : Livestream" in the bottom right hand corner. I thought it may be something corrupt with the openelec install so I did a fresh install and the same exact thing happens every time I hit "Live & Upcoming". Here is my logfile.
https://www.dropbox.com/s/p0svx0d2vw3jti...9.zip?dl=0
I've attempted to fix the line causing the error. You can download the lastest changes from the link on the first post.
(2015-08-29, 15:06)eracknaphobia Wrote: [ -> ]I've attempted to fix the line causing the error. You can download the lastest changes from the link on the first post.
That worked! Thank you so much for building this plugin.
Great! I'm glad your enjoying this plugin.
Hey man thanks for this plugin. My wife loves to watch news in the morning while getting ready for work. I am having an issue with KY3 as well as KSPR. KY3 is located at https://livestream.com/accounts/4699618/live and KSPR is at http://livestream.com/accounts/4835775/live
When going to both in the plugins they are not listed under live. When you do a search they come up but the LIVE link links to a 30 second clip on both stations instead of the most recent full stream. Is there anyway to fix this?
Both are currently live on the air but arent showing up under live.
Additionally, when running on either of my nexus player selecting the live and upcoming link gives a script failed error
@eracknaphobia, Any chance to have a look at my log and why I can't find the live transmission? Your help is much appreciated.
Yeah, I took a look and tried to figure out why it was giving the wrong video link. I've haven't found a solution yet.
(2015-08-31, 05:15)cnmsales Wrote: [ -> ]Hey man thanks for this plugin. My wife loves to watch news in the morning while getting ready for work. I am having an issue with KY3 as well as KSPR. KY3 is located at https://livestream.com/accounts/4699618/live and KSPR is at http://livestream.com/accounts/4835775/live
I believe this issue is similar to the one MrBogus is having. I'll see if i can find a solution.
If you download the zip file from the first post it should fix the error that nikki7luc & T5740 reported.
(2015-07-07, 14:21)eracknaphobia Wrote: [ -> ]
(2015-07-07, 13:38)harpua1982 Wrote: [ -> ]This,
http://livestream.com/accounts/11327981/events/3653563, for example, is a local news channel that I'm following on LS. I am unable to search and find the channel (probably b/c the channel is simply labeled, "Live") through the addon, but I am in the LS app.
When I search for "WIS" on the web page I don't see it in the results. This is why the addon doesn't work, it runs the same command.
Hi eracknaphobia
On Livestream.com search for "quehuong" it show up the Live Stream below:
http://livestream.com/accounts/8536579/events/3475355
But in Kodi, its result is the video not the live stream at the same page.
Could you please fix it?
Thank you!
Version 2015.8.31 Released
I've updated the code to in attempt fix the live search results not playing the correct stream. Please download the zip from the first post.
Thanks man. I will give it a test and report back to you. Cheers!
Hey man. I've installed it and I have some feed back. Clicking on live and upcoming still gives a script error and doesn't load.
When searching for ky3 and playing the link it is now playing the most recent "live" feed.
Any idea on why the love and upcoming link isn't working?
Btw, thank you for taking the time to fix this. My wife will be very grateful. You are making convincing the wife cord cutting is a good idea much much easier.
(2015-09-01, 04:24)cnmsales Wrote: [ -> ]Hey man. I've installed it and I have some feed back. Clicking on live and upcoming still gives a script error and doesn't load.
Hahaha, no problem. Glad I could help. If you can get me a log file I can take a look and see where the error is occurring.
http://kodi.wiki/view/Log_file/Easy
EDIT: Nevermind, I accidentally removed the previous fix for Live & Upcoming when releasing the latest fix for the Live Search. They should both be in the newest version (2015.9.1) and can be downloaded from the first post.
I'll add a pull request to the official kodi repo once I get some feedback.
Great job eracknaphobia! For me it works now using openelec. Thanks a lot.
