Full Version: Livestream
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Updated
v2015.9.21
- Fix for live & archive search errors
(2015-09-22, 01:05)Iceclaw Wrote: [ -> ]Any idea why KOLD still isn't turning up?
http://livestream.com/accounts/11042990/
http://livestream.com/KOLD
http://livestream.com/KOLD/live
I'll have a look and see what I can figure out.
Thanks, Trying to get my parents all setup =)
V2015.9.22
- Removed Search Archive
- Search now has the ability to list events, accounts and videos separately
- When selecting an account, videos are separated into Upcoming and Past events
(2015-09-22, 17:15)Iceclaw Wrote: [ -> ]Thanks, Trying to get my parents all setup =)
Nice.
The latest update should help. KOLD shows up in the Accounts section when searching "KOLD". After you select the account it should list their live feed and past videos if applicable.
Tested and love the account search feature. Able to find all my favorite sport accounts by manual search which previously had never worked.
I guess login is the only feature left, but I don't have any idevices so don't know if it is supported on those.
Great job!!! Everything works very well, include the install via zip-archive.
So many thanks!
Nice work and I really appreciate how responsive you are! This works really well now and I hate to bug you with another "I can't find X," but I'm trying to get some friends set up and I can't find Fox 40 http://livestream.com/KTXL/live I used to be able to find it in both Live & Upcoming and through Search, but it doesn't seem to be showing up anymore. I've tried several different search terms. Any ideas?
One more question. I have some other friends who really like this stream: http://livestream.com/karbala-tv/events/3998452 Right now it seems to be working. On the streaming page the account has some videos posted below the actual live stream. Before this update, the addon would randomly switch to playing the most recently uploaded video instead of the live stream and would never go back unless I did a reinstall of the addon (however this did not always fix it.) Do you think this latest update will solve that problem?
Thanks for everything eracknaphobia!
I've created a beta for testing the new login feature. I was only able to test it against my account, so I'm not sure if it will work right away or if it will need overhauled. So if you would like to beta test the login feature please post any errors (w/ logs) that you encounter. Thanks!
https://github.com/eracknaphobia/plugin....annels.zip
(2015-09-22, 23:28)Mckrilliams Wrote: [ -> ]Nice work and I really appreciate how responsive you are! This works really well now and I hate to bug you with another "I can't find X," but I'm trying to get some friends set up and I can't find Fox 40 http://livestream.com/KTXL/live I used to be able to find it in both Live & Upcoming and through Search, but it doesn't seem to be showing up anymore. I've tried several different search terms. Any ideas?
I was hoping the login feature would fix the KTXL issue but it doesn't. I added them to my "follow" list and they still didn't show up on my iDevices nor the livestream official website, so I'm thinking there maybe something configured incorrectly on livestreams end.
The latest update should fix this I believe.
You're welcome.
(2015-09-23, 21:03)eracknaphobia Wrote: [ -> ]I've created a beta for testing the new login feature. I was only able to test it against my account, so I'm not sure if it will work right away or if it will need overhauled. So if you would like to beta test the login feature please post any errors (w/ logs) that you encounter. Thanks!
Works great ! Thanks for adding this.Big Grin
A much needed enhancement would be how the "official" apps actually list all the "accounts you follow" first. Clicking any of the accounts you follow then gives the option of 1) Archived 2)Live and Ongoing and 3) Upcoming. Any or all of these sections could have empty elements.
The current sorting method lists all archived videos available for all accounts by default. If you follow too many accounts, it is quite a large resultset depending on which accounts you are following. It does however get all the accounts under my login. Blush
I've updated the beta with siuside's advice. My channels now loads the accounts you follow first. When you select an account the events are divided into up Live / Upcoming and Past. This new method of displaying accounts first also fixed the KTXL issue as well. For some reason their live feed is located in their past eventsHuh So that's why they weren't showing up before.
On another note, I wanted to get any opinions on what the Login / My Channels section should be called. Livestream.com has it labeled as "Your Network"
Awesome progress Smile
All of those enhancements work ! There is one last minor bug to be quashed. Under "Past Events", all events are listed chronologically with most recent event first. Seems like this is the correct way.
However under Live/Upcoming Events, it is sorted reverse, with the most recent upcoming event listed last. Again nothing major but would replicate the official app and aesthetically pleasing and keep it consistent with Past Events.
For the naming, I like "My Channels". It is actually much better than what Livestream calls it with "Following"/"Your Network" etc which probably make more sense for content providers.
We are almost there to perfection ! Great work eracknaphobia. The way I see it Livestream should be paying you for making it this awesome Big Grin
Edit: Spotted one more bug.
After selecting a "Past Event", it is not sorting out the different videos of that past live event. It auto selects the first video although there could be several videos listed within the past live event. Example account http://livestream.com/bwfbadminton/
Not sure if this bug affects the Live/Upcoming sections too because I don't see those options for an example channel
Do you have an example account that I can test against to fix the Live / Upcoming section order? Most of my channels have one or none under the live / upcoming section currently.
