2016-05-04, 01:24
(2016-05-04, 01:18)binder420 Wrote: [ -> ]OK installed the new version still does not work on direct tv loginThank you for trying, can you upload the debug log per the instructions at http://kodi.wiki/view/Log_file/Easy ?
(2016-05-04, 01:04)awaters1 Wrote: [ -> ]@siuside
Smil url being blank is usually due to the ISP not supporting password-less login of ESPN3. Does watchespn through the browser work as is? or do you need to login to your ISP?
I added in some random fixes that I noticed so please try again.
I tried with Comcast XFINITY but theoretically every provider in the list should work.
(2016-05-04, 02:18)binder420 Wrote: [ -> ]i did upload the log on pastebin i posted the link
here it is again: http://pastebin.com/e18afQea
(2016-05-04, 03:07)shoulih Wrote: [ -> ]I got a "Please verify your username and password..." message when use Dish to view ESPN/ESPN2 contents. ESPN3 works fine for me
(2016-05-05, 01:03)samjee Wrote: [ -> ]Thanks for the great work so far on this addon. Just gave it a try using my DirecTV details and it works fine but doesn't give you a choice to chose stream quality and only plays in SD.
Would be nice if this feature could be added similar to the NBC addon so you can chose the quality or it always plays the best available.
(2016-05-06, 02:00)awaters1 Wrote: [ -> ](2016-05-05, 01:03)samjee Wrote: [ -> ]Thanks for the great work so far on this addon. Just gave it a try using my DirecTV details and it works fine but doesn't give you a choice to chose stream quality and only plays in SD.
It is supposed to be best available, to be honest I haven't looked too much into the quality. The bitrate is low (2200kbps is what I am seeing) so there is some macroblocking, I'm not sure if they offer high bitrate streams.
#EXTM3U
#EXT-X-VERSION:5
#EXT-UPLYNK-LIVE
#EXT-X-START:TIME-OFFSET=0.0
#EXT-X-INDEPENDENT-SEGMENTS
#UPLYNK-MEDIA0:320x180x30,baseline-13,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=320x180,BANDWIDTH=450560,CODECS="mp4a.40.5,avc1.42000d"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/d.m3u8
#UPLYNK-MEDIA0:512x288x30,baseline-21,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=512x288,BANDWIDTH=901120,CODECS="mp4a.40.5,avc1.420015"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/e.m3u8
#UPLYNK-MEDIA0:768x432x30,main-30,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=768x432,BANDWIDTH=1351680,CODECS="mp4a.40.5,avc1.4d001e"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/f.m3u8
#UPLYNK-MEDIA0:896x504x30,main-31,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=896x504,BANDWIDTH=2478080,CODECS="mp4a.40.5,avc1.4d001f"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/g.m3u8
#UPLYNK-MEDIA0:896x504x30,high-31,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=896x504,BANDWIDTH=3942400,CODECS="mp4a.40.5,avc1.64001f"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/h.m3u8
#UPLYNK-MEDIA0:1280x720x30,high-31,2x48000
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=1280x720,BANDWIDTH=5068800,CODECS="mp4a.40.5,avc1.64001f"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/i.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=320x180,BANDWIDTH=171212,CODECS="mp4a.40.5,avc1.42000d"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/b.m3u8
#EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=320x180,BANDWIDTH=225280,CODECS="mp4a.40.5,avc1.42000d"
http://content-ausw1.uplynk.com/channel/48ac364f60284640be93939cc754a729/c.m3u8
(2016-05-06, 02:00)awaters1 Wrote: [ -> ]I also made some updates with authentication in commit 6a28744 so if anyone had troubles before please try again. The plan is to have one pathway for every provider, but that plan may not pan out given the troubles thus far.
(2016-05-06, 03:35)awaters1 Wrote: [ -> ]Now I see, with the ESPN3 channel I can get the higher bitrates (5900ish), but the premium channels I cannot figure it out how to get more than 2200.
@locomot1f: I cannot seem to send PMs at the moment, keeps saying something about 'You do not have permission to access this page.'
(2016-05-06, 03:32)siuside Wrote: [ -> ]@MetalChris
I remember you were also impacted last year after the addon stopped working (TWC?). Are you able to get it to work with awaters version?
