GriffeyJuni0r The error is due to an issue with FFMPEG
17:17:28 T:4704 ERROR: ffmpeg[1260]: [tls] An illegal TLS extension was received.
Some channels use
http://prod-freewheel.espn.go.com for certain shows which doesn't work on windows with kodi.
I can no longer watch live TV on any of the premiums channels either.
Could yesterday. No changes from yesterday on my system, did not install anything.
Deleting the plugin , cookies file and re-authenticating didn't help this time.
All I am getting from the log is unsupported protocol(plugin).
We are SOL again on windows due to the new domains espn is using for live content as @
awaters1 pointed out. (Illegal tls extension). I ran into this yesterday and unfortunately this is the old problem.
The uplynk premiums are still working fine (sec/longhorn/espn3 etc)
siuside,
Thanks for the update. Sorry to hear that.
@OTinley: can you attach the log when it failed? It worked on my machine so I'm not sure what the issue is with installing the repository.
@siuside: The main ESPN1 channel does work sometimes, I think the issue may be that live sports use uplynk and then perhaps the documentaries/talk shows use prod-freewheel?
When I get my windows vm going I'll check if kodi 17 fixes the illegal TLS issue.
siuside
Repo zip file installed perfectly and the update was successful as well.
I found a platform that used uplynk so version 2.9.2 in the repository and the latest from develop should work correctly now. I want to work on getting this into the official repository in time for 17.x so I appreciate the testing. If you experience issues/have suggestions feel free to post them on github
https://github.com/awaters1/plugin.video.espn_3/issues
@waters1
I just applied the update you uploaded to the repo and everything works again so another +1 to your reputation and another thank you from me!
otinley
What are you thoughts about the home menu layout?
