Are there professional online techs to help set-up an XBMC/Kodi systems and, if so, can anyone recommend one? I've successfully managed to do most of it myself, but have run into a wall with a specific playback issue (getting my 1080p, 60fps home movies to play at full resolution) and can't seem to resolve it through the forums. Thanks!
Here is all the pertinent info as requested......
OSX Version: 10.10.2
Platform: Mac Mini (Mid 2011)
Processor: 2.3GHz, Intel Core i5
Memory: 8GB 1333MHz DDR3
Graphics: Intel HD Graphics 3000 512MB
Version of Kodi: 13.2
Skin: Transparency
Debug log posted at the following URL:
http://pastebin.com/u/msedaka
Playback Problems:
Won't playback 1080p 60fps footage correctly. Drops and skips frames. General look is more muted and less crisp than I would expect.
Here's a link to a screenshot with the Codec Info:
http://tinypic.com/r/mn2gx3/8
I hope this is all the information required and thank you in advance for your help!
Try a nightly build based on Isengard 15 beta - it has a much newer ffmpeg and also a different hardware codec for osx. Report back if it works better (13.2 is pretty outdated by now).
If you have issues with addons or Skins that get migrated from XBMC 13.2, when you upgrade to Kodi do this:
OSX Finder > Go > Go to Folder > ~/Library/Application Support/
Copy and paste this
exactly into Finder, including the squiggle at the start:
Rename XBMC folder and then restart Kodi.
