Full Version: Deleted IPTV Simple Client and Can't Get it to Work
I am running Kodi 14.2 on a BoxeeBox (Linux IntelICS 2.6.28) IPTV Simple Client version 1.9.12
I am also running 14.2 on a Windows 7 machine. IPTV Simple Client version 1.9.12
I have Simple IPTV running fine on my Windows system. It did not work on my BoxeeBox. Even with exactly the same URLs and configuration, my BoxeeBox would only load one channel from my XMLTV URL. So, I disabled, enabled, disabled, enabled....... Still, no luck.
I decided that "I would fix it" by uninstalling the add-on then putting it back. I uninstalled, then re-installed from the repository.
I had my Windows Kodi and my BoxeeBox Kodi side by side and verified that EVERY Live TV and IPTV Simple Client setting is identical. My Windows version still works fine, the BoxeeBox one still does not. When I enable the add-on, it says that there is a error and to check the logs.
I have a fresh log file following a reboot and an attempt to enable the add-on. If anyone has an idea, I'm willing to try most anything.... Where do I post this? Or can I simply post it into the topic?
Cheers!!
Ok, here is a snip from my log. Note the error concerning the API version...
12:25:41 T:2857221008 NOTICE: PVRManager - starting up
12:25:41 T:2971622288 NOTICE: Thread PVRManager start, auto delete: false
12:25:41 T:2972674960 NOTICE: Thread PVRClient start, auto delete: false
12:25:41 T:2972674960 DEBUG: RegisterClient - registering add-on 'PVR IPTV Simple Client'
12:25:41 T:2972674960 DEBUG: Previous line repeats 1 times.
12:25:41 T:2972674960 DEBUG: PVR - Create - creating PVR add-on instance 'PVR IPTV Simple Client'
12:25:41 T:2972674960 DEBUG: ADDON: Dll Initializing - PVR IPTV Simple Client
12:25:41 T:2972674960 DEBUG: SECTION:LoadDLL(/tmp/mnt/xbmc/addons/pvr.iptvsimple/XBMC_IPTV_Simple.pvr)
12:25:41 T:2972674960 DEBUG: Loading: /tmp/mnt/xbmc/addons/pvr.iptvsimple/XBMC_IPTV_Simple.pvr
12:25:41 T:2972674960 ERROR: PVR - Add-on 'PVR IPTV Simple Client' is using an incompatible API version. XBMC minimum API version = '1.9.2', add-on API version '1.9.0'
12:25:41 T:2972674960 WARNING: UpdateAndInitialiseClients - failed to create add-on PVR IPTV Simple Client, status = 6
12:25:41 T:2972674960 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on PVR IPTV Simple Client, disabling it
12:25:41 T:3039717088 DEBUG: CGUIMediaWindow::GetDirectory (addons://disabled/xbmc.pvrclient)
12:25:41 T:3039717088 DEBUG: ParentPath = [addons://disabled/xbmc.pvrclient]
12:25:41 T:2927549328 NOTICE: Thread BackgroundLoader start, auto delete: false
12:25:41 T:2857221008 DEBUG: GetImageHash - unable to stat url /tmp/mnt/xbmc/addons/pvr.demo/icon.png
12:25:41 T:2927549328 DEBUG: Thread BackgroundLoader 2927549328 terminating
What repository did you use. I un install by accident. Npq I can't find it . Plz help..
Try reinstalling Kodi, the PVR addons are bundled with it so if you're unlucky enough to uninstall them (you should never do that) you'll have to reinstall Kodi. If you use OpenElec 6.0 things have improved so that there's an actual official repository for PVR addons, you might want to try that at some point.
