Full Version: Unable to sync (100% movies list)
Hey guys, I am just wondering why Kodi 14.2 (windows 64bit) is not syncing all of my downloaded movies which are on my HD.
For example, I have Die Hard 1, 2 and 3 on my HD, well Die Hard 2 is synced fine, but 1 and 3 are not there, it wont sync them. They are all the same format two (mp4) and 1080p.
I also have other movies which fail to sync - mostly .mkv or .mp4 (some actually do sync fine though) so what is causing the problem and is there a way I can fix it please?
Thank you.
What are the filenames and paths for these movies? that might give us a clue what is going wrong. You could also check the logfile to see what is going on.
Oooo yea, forgot about the log file, tried to give as much info as possible but forgot this Tongue
Log file:
08:28:55 T:7748  NOTICE: special://profile/ is mapped to: special://masterprofile/
08:28:55 T:7748  NOTICE: -----------------------------------------------------------------------
08:28:55 T:7748  NOTICE: Starting Kodi (14.2 Git:20150326-7cc53a9). Platform: Windows NT x86 32-bit
08:28:55 T:7748  NOTICE: Using Release Kodi x32 build
08:28:55 T:7748  NOTICE: Kodi compiled Mar 26 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
08:28:55 T:7748  NOTICE: Running on Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
08:28:55 T:7748  NOTICE: Host CPU: AMD FX(tm)-8320 Eight-Core Processor, 8 cores available
08:28:55 T:7748  NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
08:28:55 T:7748  NOTICE: Running with administrator rights
08:28:55 T:7748  NOTICE: Aero is enabled
08:28:55 T:7748  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
08:28:55 T:7748  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
08:28:55 T:7748  NOTICE: special://masterprofile/ is mapped to: C:\Users\DarkXess\AppData\Roaming\Kodi\userdata
08:28:55 T:7748  NOTICE: special://home/ is mapped to: C:\Users\DarkXess\AppData\Roaming\Kodi\
08:28:55 T:7748  NOTICE: special://temp/ is mapped to: C:\Users\DarkXess\AppData\Roaming\Kodi\cache
08:28:55 T:7748  NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
08:28:55 T:7748  NOTICE: Local hostname: Sector7
08:28:55 T:7748  NOTICE: Log File is located: C:\Users\DarkXess\AppData\Roaming\Kodi\kodi.log
08:28:56 T:7748  NOTICE: load settings...
08:28:56 T:7748 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
08:28:56 T:7748 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
08:28:56 T:7748  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
08:28:56 T:7748  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
08:28:56 T:7748  NOTICE: Default DVD Player: dvdplayer
08:28:56 T:7748  NOTICE: Default Video Player: dvdplayer
08:28:56 T:7748  NOTICE: Default Audio Player: paplayer
08:28:56 T:7748  NOTICE: Disabled debug logging due to GUI setting. Level 0.
08:28:56 T:7748  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
08:28:56 T:7748  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
08:28:56 T:7748  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
08:28:56 T:7748  NOTICE: Loaded playercorefactory configuration
08:28:56 T:7748  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
08:28:56 T:7748  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
08:28:56 T:9116  NOTICE: Thread ActiveAE start, auto delete: false
08:28:56 T:7556  NOTICE: Thread AESink start, auto delete: false
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "LEN LI2323swA-4 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "LEN LI2323swA-0 (NVIDIA High Definition Audio)" seems to be not supported.
08:28:56 T:9116  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "SPDIF-Out (2- Sound Blaster Z)" seems to be not supported.
08:28:57 T:9116  NOTICE: Found 2 Lists of Devices
08:28:57 T:9116  NOTICE: Enumerated DIRECTSOUND devices:
08:28:57 T:9116  NOTICE:     Device 1
08:28:57 T:9116  NOTICE:         m_deviceName      : {20C774B3-7183-450A-B345-5BB25DFC2F6B}
08:28:57 T:9116  NOTICE:         m_displayName     : HDMI - LEN LI2323swA-4 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: LEN LI2323swA-4 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
08:28:57 T:9116  NOTICE:         m_channels        : FL,FR
08:28:57 T:9116  NOTICE:         m_sampleRates     : 48000
08:28:57 T:9116  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
08:28:57 T:9116  NOTICE:     Device 2
08:28:57 T:9116  NOTICE:         m_deviceName      : {338B3511-3FE6-4628-8D9B-543C72BC44B2}
08:28:57 T:9116  NOTICE:         m_displayName     : SPDIF - Realtek Digital Output(Optical) (Realtek High Definition Audio)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: Realtek Digital Output(Optical) (Realtek High Definition Audio)
08:28:57 T:9116  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
08:28:57 T:9116  NOTICE:     Device 3
08:28:57 T:9116  NOTICE:         m_deviceName      : {681E21C3-97C1-42B8-956B-0D19345BD708}
08:28:57 T:9116  NOTICE:         m_displayName     : HDMI - LEN LI2323swA-0 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: LEN LI2323swA-0 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:     Device 4
08:28:57 T:9116  NOTICE:         m_deviceName      : {9183FE87-C383-42ED-A17A-35B1E642E665}
08:28:57 T:9116  NOTICE:         m_displayName     : SPDIF - SPDIF-Out (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: SPDIF-Out (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:     Device 5
08:28:57 T:9116  NOTICE:         m_deviceName      : {A0EAC7C8-43AA-4406-8B52-F49CF05E0089}
08:28:57 T:9116  NOTICE:         m_displayName     : Speakers - Speakers (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: Speakers (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
08:28:57 T:9116  NOTICE:     Device 6
08:28:57 T:9116  NOTICE:         m_deviceName      : default
08:28:57 T:9116  NOTICE:         m_displayName     : default
08:28:57 T:9116  NOTICE:     Device 7
08:28:57 T:9116  NOTICE:         m_deviceName      : {B0338576-B5D6-464F-A81B-55335B8017DF}
08:28:57 T:9116  NOTICE:         m_displayName     : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: DIRECTSOUND: Realtek Digital Output (Realtek High Definition Audio)
08:28:57 T:9116  NOTICE: Enumerated WASAPI devices:
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: LEN LI2323swA-4 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:         m_sampleRates     : 192000,48000,44100
08:28:57 T:9116  NOTICE:         m_dataFormats     : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: Realtek Digital Output(Optical) (Realtek High Definition Audio)
08:28:57 T:9116  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
08:28:57 T:9116  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: LEN LI2323swA-0 (NVIDIA High Definition Audio)
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: SPDIF-Out (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:         m_sampleRates     : 192000,96000,88200,48000,44100
08:28:57 T:9116  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: Speakers (2- Sound Blaster Z)
08:28:57 T:9116  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
08:28:57 T:9116  NOTICE:         m_dataFormats     : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
08:28:57 T:9116  NOTICE:         m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
08:28:57 T:7748  NOTICE: Running database version Addons16
08:28:57 T:7748  NOTICE: ADDONS: Using repository repository.aeon-mq5-mod-helix
08:28:57 T:7748  NOTICE: ADDONS: Using repository repository.xbmc.org
08:28:57 T:7748  NOTICE: ADDONS: Using repository repository.xunitytalk
08:28:57 T:7748  NOTICE: ADDONS: Using repository superrepo.kodi.helix.all
08:28:57 T:7748  NOTICE: ADDONS: Using repository repository.xbmchub
08:28:57 T:7748  NOTICE: ADDONS: Using repository repository.totalinstaller
08:28:57 T:5476  NOTICE: Thread RemoteControl start, auto delete: false
08:28:57 T:988  NOTICE: Thread PeripBusCEC start, auto delete: false
08:28:57 T:8820  NOTICE: Thread PeripBusUSB start, auto delete: false
08:28:57 T:7748  NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 660  , adapter 0.
08:28:57 T:7748  NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 660  , adapter 1.
08:28:57 T:7748  NOTICE: Primary mode: [email protected] 60.00 - Full Screen
08:28:57 T:7748  NOTICE: Secondary mode: [email protected] 60.00 #2 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 56.00 - Full Screen
08:28:57 T:7748  NOTICE: Previous line repeats 2 times.
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 60.00 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 72.00 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 75.00 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 59.94 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 50.00 - Full Screen
08:28:57 T:7748  NOTICE: Additional mode: [email protected] 70.00 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 60.00 - Full Screen
08:28:58 T:7748  NOTICE: Previous line repeats 2 times.
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 70.00 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 75.00 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 59.94 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 25.00i - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 30.00i - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 29.97i - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 50.00 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 60.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 59.94 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 30.00i #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 29.97i #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 50.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 25.00i #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 56.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 72.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 75.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Additional mode: [email protected] 70.00 #2 - Full Screen
08:28:58 T:7748  NOTICE: Checking resolution 16
08:28:59 T:7748  NOTICE: Running database version Addons16
08:28:59 T:7748  NOTICE: Running database version ViewModes6
08:28:59 T:7748  NOTICE: Running database version Textures13
08:28:59 T:7748  NOTICE: Running database version MyMusic48
08:28:59 T:7748  NOTICE: Running database version MyVideos90
08:28:59 T:7748  NOTICE: Running database version TV26
08:28:59 T:7748  NOTICE: Running database version Epg8
08:28:59 T:7748 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
08:28:59 T:7748 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
08:28:59 T:7748 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
08:28:59 T:7748 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
08:28:59 T:10228  NOTICE: Thread LanguageInvoker start, auto delete: false
08:28:59 T:7748  NOTICE: Previous line repeats 9 times.
08:28:59 T:7748  NOTICE: initialize done
08:28:59 T:7844  NOTICE: Thread LanguageInvoker start, auto delete: false
08:28:59 T:7748  NOTICE: Running the application...
08:28:59 T:8880  NOTICE: -->Python Interpreter Initialized<--
08:28:59 T:4912  NOTICE: Thread JobWorker start, auto delete: true
08:28:59 T:7748  NOTICE: ES: Starting event server
08:28:59 T:8588  NOTICE: Thread EventServer start, auto delete: false
08:28:59 T:8588  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
08:28:59 T:4288  NOTICE: Thread JobWorker start, auto delete: true
08:28:59 T:9656  NOTICE: Thread RSSReader start, auto delete: false
08:28:59 T:7224  NOTICE: Thread TCPServer start, auto delete: false
08:28:59 T:8588  NOTICE: UDP: Listening on port 9777
08:28:59 T:10228  NOTICE: -->Python Interpreter Initialized<--
08:29:00 T:7080  NOTICE: Previous line repeats 9 times.
08:29:00 T:7080  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.14)
08:29:00 T:7388  NOTICE: Thread LanguageInvoker start, auto delete: false
08:29:00 T:6428  NOTICE: RCB Service: Start
08:29:00 T:6428  NOTICE: RCB Service: launch RCB on startup = false
08:29:00 T:6428  NOTICE: RCB Service: scrape games on startup = false
08:29:00 T:6428  NOTICE: RCB Service: Done
08:29:00 T:2932  NOTICE: Thread JobWorker start, auto delete: true
08:29:00 T:8492  NOTICE:  StorageServer Module loaded RUN
08:29:01 T:8492  NOTICE: StorageClient-2.5.4 Starting server
08:29:01 T:7120  NOTICE: 1Channel: Service: Installed Version: 2.5.64
08:29:01 T:7120  NOTICE: 1Channel: Loading sqlite3 as DB engine
08:29:01 T:7120  NOTICE: 1Channel: Service: Resetting...
08:29:01 T:7120  NOTICE: 1Channel: Service: starting...
08:29:01 T:7388  NOTICE: -->Python Interpreter Initialized<--
08:29:01 T:7388  NOTICE: CommonFunctions-2.5.1
08:29:01 T:9656   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
08:29:01 T:9656   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
08:29:04 T:7600  NOTICE: Thread JobWorker start, auto delete: true
08:29:04 T:7844  NOTICE: http://tribeca.tvaddons.ag/tools/notifications/news.txt
08:29:04 T:7844  NOTICE: ['notifications-on-startup', False, 'DoFromService', True]
08:29:04 T:7844  NOTICE: ['OLD', 't', '6', "We're very excited to announce the release of the much anticipated update to TVMC for\nAndroid, just a couple of weeks behind the Windows and Mac versions. This is not\nsomething that you want to miss, it will make your Kodi experience on new devices\nso much easier.\n\nTVMC is a custom version of Kodi that comes with all the best add-ons and tweaks\npreconfigured for your enjoyment! Just install and enjoy, no hassles! Please visit the\nfollowing page for more information: [B][COLOR white]www.tvaddons.ag/tvmc-cordcutters[/COLOR][/B]\n\nPlease take the time to share this special release with as many people as possible,\nsend it to your friends, family, coworkers, neighbours, and anyone else you can think\nof who would enjoy Kodi as much as you do! Thank you again for your support."]
08:29:04 T:7844  NOTICE: ['NEW', 't', '6', "We're very excited to announce the release of the much anticipated update to TVMC for\nAndroid, just a couple of weeks behind the Windows and Mac versions. This is not\nsomething that you want to miss, it will make your Kodi experience on new devices\nso much easier.\n\nTVMC is a custom version of Kodi that comes with all the best add-ons and tweaks\npreconfigured for your enjoyment! Just install and enjoy, no hassles! Please visit the\nfollowing page for more information: [B][COLOR white]www.tvaddons.ag/tvmc-cordcutters[/COLOR][/B]\n\nPlease take the time to share this special release with as many people as possible,\nsend it to your friends, family, coworkers, neighbours, and anyone else you can think\nof who would enjoy Kodi as much as you do! Thank you again for your support."]
08:29:07 T:7956  NOTICE: Thread BackgroundLoader start, auto delete: false
08:29:08 T:5768  NOTICE: Thread FileCache start, auto delete: false
08:29:10 T:7624  NOTICE: Thread VideoInfoScanner start, auto delete: false
08:29:10 T:7624  NOTICE: VideoInfoScanner: Starting scan ..
08:29:18 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\23;59\23;59.mkv', it won't be added to the library.
08:29:18 T:4288   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
08:29:18 T:4288   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
08:29:18 T:4288   ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.kodi.tv/addons/gotham/addons.xml.md5>
08:29:18 T:4288   ERROR: Failed to fetch checksum for directory listing http://mirrors.kodi.tv/addons/gotham/addons.xml for repository repository.xbmc.org.
08:29:19 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Black & WhiteThe Dawn of Justice\Black & WhiteThe Dawn of Justice.avi', it won't be added to the library.
08:29:20 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Gojira (Aka - Godzilla)\Gojira (Aka - Godzilla).mkv', it won't be added to the library.
08:29:24 T:2440  NOTICE: Thread FileCache start, auto delete: false
08:29:31 T:7624  NOTICE: Previous line repeats 1 times.
08:29:31 T:7624 WARNING: No information found for item 'stack://E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD1.avi , E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD2.avi', it won't be added to the library.
08:29:32 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Riger Mortis\Riger Mortis.mp4', it won't be added to the library.
08:29:32 T:8888  NOTICE: Thread FileCache start, auto delete: false
08:29:33 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Chef the Actor and the Scoundrel\The Chef the Actor and the Scoundrel.mkv', it won't be added to the library.
08:29:33 T:8024  NOTICE: Thread BackgroundLoader start, auto delete: false
08:29:34 T:7624 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Vengeance - Trilogy\Sympathy For Mr.Vengeance\Sympathy For Mr.Vengeance.mp4', it won't be added to the library.
08:29:35 T:7624  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:25
08:29:35 T:8520  NOTICE: Thread BackgroundLoader start, auto delete: false
08:31:38 T:8276  NOTICE: Previous line repeats 23 times.
08:31:39 T:8276  NOTICE: Thread JobWorker start, auto delete: true
08:31:39 T:9752  NOTICE: Thread BackgroundLoader start, auto delete: false
08:32:08 T:8276  NOTICE: Previous line repeats 1 times.
08:32:08 T:8276   ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://image.tmdb.org/t/p/original/i34dh4LKYlNOF67qSPJgzhddzyw.jpg
08:32:11 T:8352  NOTICE: Thread BackgroundLoader start, auto delete: false
08:32:16 T:8428  NOTICE: Thread VideoInfoScanner start, auto delete: false
08:32:16 T:8428  NOTICE: VideoInfoScanner: Starting scan ..
08:32:19 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\23;59\23;59.mkv', it won't be added to the library.
08:32:20 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Black & WhiteThe Dawn of Justice\Black & WhiteThe Dawn of Justice.avi', it won't be added to the library.
08:32:21 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Gojira (Aka - Godzilla)\Gojira (Aka - Godzilla).mkv', it won't be added to the library.
08:32:23 T:8428 WARNING: No information found for item 'stack://E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD1.avi , E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD2.avi', it won't be added to the library.
08:32:24 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Riger Mortis\Riger Mortis.mp4', it won't be added to the library.
08:32:25 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Chef the Actor and the Scoundrel\The Chef the Actor and the Scoundrel.mkv', it won't be added to the library.
08:32:26 T:10040  NOTICE: Thread FileCache start, auto delete: false
08:32:29 T:8428  NOTICE: Previous line repeats 1 times.
08:32:29 T:8428 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Vengeance - Trilogy\Sympathy For Mr.Vengeance\Sympathy For Mr.Vengeance.mp4', it won't be added to the library.
08:32:29 T:8428  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:13
08:32:35 T:8052  NOTICE: Thread FileCache start, auto delete: false
08:39:05 T:7260  NOTICE: Thread JobWorker start, auto delete: true
08:48:16 T:3516  NOTICE: Previous line repeats 1 times.
08:48:16 T:3516   ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.google.com/
08:48:36 T:3516   ERROR: CCurlFile::Exists - Failed: Couldn't connect to server(7) for http://www.google.com/
08:48:56 T:3516   ERROR: CCurlFile::Exists - Failed: Timeout was reached(28) for http://www.google.com/
08:49:56 T:3516   ERROR: Previous line repeats 2 times.
08:49:56 T:3516   ERROR: CCurlFile::Exists - Failed: Couldn't connect to server(7) for http://www.google.com/
08:50:43 T:3548   ERROR: Previous line repeats 2 times.
08:50:43 T:3548  NOTICE: Thread BackgroundLoader start, auto delete: false
08:50:43 T:5324  NOTICE: Thread JobWorker start, auto delete: true
08:50:45 T:6116  NOTICE: Previous line repeats 1 times.
08:50:45 T:6116  NOTICE: Thread VideoInfoScanner start, auto delete: false
08:50:45 T:6116  NOTICE: VideoInfoScanner: Starting scan ..
08:51:25 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\23;59\23;59.mkv', it won't be added to the library.
08:51:26 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Black & WhiteThe Dawn of Justice\Black & WhiteThe Dawn of Justice.avi', it won't be added to the library.
08:51:28 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Gojira (Aka - Godzilla)\Gojira (Aka - Godzilla).mkv', it won't be added to the library.
08:51:29 T:6116 WARNING: No information found for item 'stack://E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD1.avi , E:\Entertainment\Movies\World Cinema\R2B Return 2 Base\R2B Return 2 Base CD2.avi', it won't be added to the library.
08:51:30 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\Riger Mortis\Riger Mortis.mp4', it won't be added to the library.
08:51:36 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Chef the Actor and the Scoundrel\The Chef the Actor and the Scoundrel.mkv', it won't be added to the library.
08:51:37 T:6116 WARNING: No information found for item 'E:\Entertainment\Movies\World Cinema\The Vengeance - Trilogy\Sympathy For Mr.Vengeance\Sympathy For Mr.Vengeance.mp4', it won't be added to the library.
08:51:37 T:6116  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:52
08:51:37 T:2440  NOTICE: Thread JobWorker start, auto delete: true
08:52:40 T:3516   ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://image.tmdb.org/t/p/original/1EG5K8vovv6Hp9XvUplPDlJFPNz.jpg
08:53:09 T:3516   ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for http://image.tmdb.org/t/p/original/vKmIyAdXrO0G6N92xCmWSysxiZv.jpg
08:54:21 T:3516   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
08:54:21 T:3516   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
08:55:15 T:2904  NOTICE: Thread JobWorker start, auto delete: true
08:55:22 T:6716  NOTICE: Thread BackgroundLoader start, auto delete: false
08:55:22 T:10040  NOTICE: Thread JobWorker start, auto delete: true
08:55:33 T:8036  NOTICE: Previous line repeats 1 times.
08:55:33 T:8036  NOTICE: Thread BackgroundLoader start, auto delete: false
08:56:56 T:7748  NOTICE: Previous line repeats 1 times.
08:56:56 T:7748  NOTICE: DVDPlayer: Opening: E:\Entertainment\Movies\Box Sets\Die Hard Trilogy\Die Hard 2.mp4
08:56:56 T:7748 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:56:56 T:8260  NOTICE: Thread DVDPlayer start, auto delete: false
08:56:56 T:8260  NOTICE: Creating InputStream
08:56:56 T:8260  NOTICE: Creating Demuxer
08:56:56 T:8260  NOTICE: Opening stream: 0 source: 256
08:56:56 T:8260  NOTICE: Creating video codec with codec id: 28
08:56:56 T:8260  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
08:56:56 T:8260  NOTICE: Creating video thread
08:56:56 T:8260  NOTICE: Opening stream: 1 source: 256
08:56:56 T:8760  NOTICE: Thread DVDPlayerVideo start, auto delete: false
08:56:56 T:8260  NOTICE: Finding audio codec for: 86018
08:56:56 T:8760  NOTICE: running thread: video_thread
08:56:56 T:8260  NOTICE: Creating audio thread
08:56:56 T:8260  NOTICE: Opening stream: 0 source: 1024
08:56:56 T:5184  NOTICE: Thread DVDPlayerAudio start, auto delete: false
08:56:56 T:5184  NOTICE: running thread: CDVDPlayerAudio::Process()
08:56:56 T:8760   ERROR: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video returned failure
08:56:56 T:5184  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
08:56:56 T:8760  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:56:56 T:8760  NOTICE: Previous line repeats 1 times.
08:56:56 T:8760  NOTICE: DXVA::CDecoder::Close - closing decoder
08:56:56 T:8760  NOTICE:  fps: 23.976024, pwidth: 1920, pheight: 812, dwidth: 1920, dheight: 812
08:56:56 T:8760  NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
08:56:56 T:8760  NOTICE: D3D: rendering method forced to DXVA processor
08:56:56 T:7748 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
08:56:56 T:7120  NOTICE: 1Channel: Service: Playback started
08:56:59 T:8760  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:56:59 T:8760  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:00 T:8760  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:01 T:8760  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:02 T:8760  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:02 T:8760  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:06 T:7748  NOTICE: CDVDPlayer::CloseFile()
08:57:06 T:7748  NOTICE: DVDPlayer: waiting for threads to exit
08:57:06 T:8260  NOTICE: CDVDPlayer::OnExit()
08:57:06 T:8260  NOTICE: Closing stream player 1
08:57:06 T:8260  NOTICE: Waiting for audio thread to exit
08:57:06 T:5184  NOTICE: thread end: CDVDPlayerAudio::OnExit()
08:57:06 T:8260  NOTICE: Closing audio device
08:57:06 T:8260  NOTICE: Deleting audio codec
08:57:06 T:8260  NOTICE: Closing stream player 2
08:57:06 T:8260  NOTICE: waiting for video thread to exit
08:57:06 T:8760  NOTICE: thread end: video_thread
08:57:06 T:8260  NOTICE: deleting video codec
08:57:06 T:8260  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:06 T:8260  NOTICE: DXVA::Close - closing decoder context
08:57:06 T:8260  NOTICE: Closing stream player 3
08:57:06 T:7748  NOTICE: DVDPlayer: finished waiting
08:57:06 T:7120  NOTICE: 1Channel: Service: Playback Stopped
08:57:06 T:7120  NOTICE: 1Channel: Service: Resetting...
08:57:06 T:7808  NOTICE: Thread BackgroundLoader start, auto delete: false
08:57:07 T:7748  NOTICE: DVDPlayer: Opening: E:\Entertainment\Movies\Box Sets\Die Hard Trilogy\Die Hard 2.mp4
08:57:07 T:7748 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:57:07 T:2652  NOTICE: Thread DVDPlayer start, auto delete: false
08:57:07 T:2652  NOTICE: Creating InputStream
08:57:07 T:2652  NOTICE: Creating Demuxer
08:57:07 T:2652  NOTICE: Opening stream: 0 source: 256
08:57:07 T:2652  NOTICE: Creating video codec with codec id: 28
08:57:07 T:2652  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
08:57:07 T:2652  NOTICE: Creating video thread
08:57:07 T:2652  NOTICE: Opening stream: 1 source: 256
08:57:07 T:2652  NOTICE: Finding audio codec for: 86018
08:57:07 T:6716  NOTICE: Thread DVDPlayerVideo start, auto delete: false
08:57:07 T:6716  NOTICE: running thread: video_thread
08:57:07 T:2652  NOTICE: Creating audio thread
08:57:07 T:2652  NOTICE: Opening stream: 0 source: 1024
08:57:07 T:9932  NOTICE: Thread DVDPlayerAudio start, auto delete: false
08:57:07 T:9932  NOTICE: running thread: CDVDPlayerAudio::Process()
08:57:07 T:6716   ERROR: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video returned failure
08:57:07 T:9932  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
08:57:07 T:6716  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:07 T:7120  NOTICE: Previous line repeats 1 times.
08:57:07 T:7120  NOTICE: 1Channel: Service: Playback started
08:57:07 T:6716  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:07 T:6716  NOTICE:  fps: 23.976024, pwidth: 1920, pheight: 812, dwidth: 1920, dheight: 812
08:57:07 T:6716  NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
08:57:07 T:6716  NOTICE: D3D: rendering method forced to DXVA processor
08:57:07 T:7748 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
08:57:10 T:6716  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:10 T:6716  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:10 T:9932 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
08:57:13 T:6716 WARNING: Previous line repeats 4 times.
08:57:13 T:6716  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:13 T:6716  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:14 T:6716  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x812)
08:57:14 T:6716  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:16 T:7748  NOTICE: CDVDPlayer::CloseFile()
08:57:16 T:7748  NOTICE: DVDPlayer: waiting for threads to exit
08:57:16 T:2652  NOTICE: CDVDPlayer::OnExit()
08:57:16 T:2652  NOTICE: Closing stream player 1
08:57:16 T:2652  NOTICE: Waiting for audio thread to exit
08:57:16 T:9932  NOTICE: thread end: CDVDPlayerAudio::OnExit()
08:57:16 T:2652  NOTICE: Closing audio device
08:57:16 T:2652  NOTICE: Deleting audio codec
08:57:16 T:2652  NOTICE: Closing stream player 2
08:57:16 T:2652  NOTICE: waiting for video thread to exit
08:57:16 T:6716  NOTICE: thread end: video_thread
08:57:16 T:2652  NOTICE: deleting video codec
08:57:16 T:2652  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:16 T:2652  NOTICE: DXVA::Close - closing decoder context
08:57:16 T:2652  NOTICE: Closing stream player 3
08:57:16 T:7748  NOTICE: DVDPlayer: finished waiting
08:57:16 T:7120  NOTICE: 1Channel: Service: Playback Stopped
08:57:16 T:7120  NOTICE: 1Channel: Service: Resetting...
08:57:16 T:9752  NOTICE: Thread BackgroundLoader start, auto delete: false
08:57:17 T:7748  NOTICE: DVDPlayer: Opening: E:\Entertainment\Movies\Box Sets\Die Hard Trilogy\Die Hard.mp4
08:57:17 T:7748 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
08:57:17 T:9592  NOTICE: Thread DVDPlayer start, auto delete: false
08:57:17 T:9592  NOTICE: Creating InputStream
08:57:17 T:9592  NOTICE: Creating Demuxer
08:57:17 T:9592  NOTICE: Opening stream: 0 source: 256
08:57:17 T:9592  NOTICE: Creating video codec with codec id: 28
08:57:17 T:9592  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
08:57:17 T:9592  NOTICE: Creating video thread
08:57:17 T:9592  NOTICE: Opening stream: 1 source: 256
08:57:17 T:3348  NOTICE: Thread DVDPlayerVideo start, auto delete: false
08:57:17 T:9592  NOTICE: Finding audio codec for: 86018
08:57:17 T:3348  NOTICE: running thread: video_thread
08:57:17 T:9592  NOTICE: Creating audio thread
08:57:17 T:9592  NOTICE: Opening stream: 0 source: 1024
08:57:17 T:1524  NOTICE: Thread DVDPlayerAudio start, auto delete: false
08:57:17 T:1524  NOTICE: running thread: CDVDPlayerAudio::Process()
08:57:17 T:3348   ERROR: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video returned failure
08:57:17 T:1524  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
08:57:17 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:17 T:3348  NOTICE: Previous line repeats 1 times.
08:57:17 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:17 T:3348  NOTICE:  fps: 23.976024, pwidth: 1918, pheight: 812, dwidth: 1916, dheight: 812
08:57:17 T:3348  NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
08:57:17 T:3348  NOTICE: D3D: rendering method forced to DXVA processor
08:57:18 T:7748 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
08:57:18 T:7120  NOTICE: 1Channel: Service: Playback started
08:57:19 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:19 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:20 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:20 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:22 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:22 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:25 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:25 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:26 T:3348  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1918x812)
08:57:26 T:3348  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:26 T:1524 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
08:57:28 T:7748 WARNING: Previous line repeats 2 times.
08:57:28 T:7748  NOTICE: CDVDPlayer::CloseFile()
08:57:28 T:7748  NOTICE: DVDPlayer: waiting for threads to exit
08:57:28 T:9592  NOTICE: CDVDPlayer::OnExit()
08:57:28 T:9592  NOTICE: Closing stream player 1
08:57:28 T:9592  NOTICE: Waiting for audio thread to exit
08:57:28 T:1524  NOTICE: thread end: CDVDPlayerAudio::OnExit()
08:57:28 T:9592  NOTICE: Closing audio device
08:57:28 T:9592  NOTICE: Deleting audio codec
08:57:28 T:9592  NOTICE: Closing stream player 2
08:57:28 T:9592  NOTICE: waiting for video thread to exit
08:57:28 T:3348  NOTICE: thread end: video_thread
08:57:28 T:9592  NOTICE: deleting video codec
08:57:28 T:9592  NOTICE: DXVA::CDecoder::Close - closing decoder
08:57:28 T:9592  NOTICE: DXVA::Close - closing decoder context
08:57:28 T:9592  NOTICE: Closing stream player 3
08:57:28 T:7748  NOTICE: DVDPlayer: finished waiting
08:57:28 T:5208  NOTICE: Thread BackgroundLoader start, auto delete: false
08:57:28 T:7120  NOTICE: 1Channel: Service: Playback Stopped
08:57:28 T:7120  NOTICE: 1Channel: Service: Resetting...
08:57:29 T:7192  NOTICE: Thread BackgroundLoader start, auto delete: false
08:57:41 T:7748  NOTICE: Storing total System Uptime
08:57:41 T:7748  NOTICE: Saving settings
08:57:41 T:7748  NOTICE: stop all
08:57:41 T:7748  NOTICE: stop player
08:57:41 T:7748  NOTICE: ES: Stopping event server
08:57:41 T:8588  NOTICE: ES: UDP Event server stopped
08:57:41 T:7748  NOTICE: stop sap announcement listener
08:57:41 T:7748  NOTICE: clean cached files!
08:57:41 T:7748  NOTICE: unload skin
08:57:41 T:7748 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-nofocus.png
08:57:41 T:7748 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-focus.png
08:57:45 T:7120  NOTICE: 1Channel: Service: shutting down...
08:57:45 T:10120 WARNING: CPythonInvoker(2, C:\Users\DarkXess\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py): the python script "C:\Users\DarkXess\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
08:57:45 T:8492  NOTICE: StorageServer-2.5.4 Closed down
08:57:46 T:2076 WARNING: CPythonInvoker(3, C:\Users\DarkXess\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): the python script "C:\Users\DarkXess\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
08:57:47 T:7080  NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
08:57:52 T:7748  NOTICE: stopped
08:57:52 T:7748  NOTICE: destroy
08:57:52 T:7748  NOTICE: closing down remote control service
08:57:52 T:7748  NOTICE: unload sections
08:57:52 T:7748  NOTICE: special://profile/ is mapped to: special://masterprofile/
08:57:52 T:7748 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
08:57:52 T:7748 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
08:57:52 T:7748  NOTICE: application stopped...
08:57:52 T:7748   ERROR: dllFreeLibrary - Invalid hModule specified
I hope its ok and safe to post the log file here, if not then please do tell me - thank you.
Your titles are not named correctly so they will not be scraped and added to your library and will appear as missing. You should be able to confirm this by comparing your video library to your movie library.
http://kodi.wiki/view/Naming_video_files/TV_shows
https://www.themoviedb.org/
Also, the missing movie scanner is a good addon to see which movies are not scraped.
Thanks guys, after going over the names and filling in the mistakes it fixed everything - thanks Smile
