Full Version: Hebrew Subtitles
Hi all. Hope this is the right place for this post.
I found it impossible to set up external Hebrew subtitles to show through DLNA on my LG TV (everything works perfectly on the Mac Kodi is installed on - Mac Pro OS X 10.9.5).
Then I decided to install Kodi 15 Isengard. I was happy to find out that after the switch everything worked flawlessly including external Hebrew subtitles over DLNA.
Yesterday I launched Kodi and got an update recommendation, so I did (updated to the current beta - Kodi 15.0 RC1 Git:2015-06-23-e916ffa).
Unfortunately I'm back to not being able to stream a video with external Hebrew subtitles.
Any ideas?
Have you looked into the settings? Go into SETTINGS then SERVICES and look at UPnP / DLNA
Notice there are now options in here to choose if external subtitles are used.
(You'll need to change the Settings Level to Advanced or Expert to see this option)
Thanks for the replay!
I guess it was just what I was missing.
External subtitles are working now, although I have to reconnect Kodi to my LG TV every time I want to use external subtitles.
Glad I could help Smile
