Full Version: UPDATE! No full screen on Kodi 15.0
Just installed Kodi 15.0 on a MK808B Plus Quad Core Android 4.4 Mini TV Dongle. I was unable to get a full screen display on my videos. Uninstalled 15.0 and installed 14.2 and everything worked just fine until today without me doing anything it became 15.0 and again no full screen display (video playback only). Could not find a "full screen" setting . Please help.
many thanks[/b]
Just took my MK808B plus and set it up on my LG TV Kodi 15.0 is working perfect with full screen, the problem is on my 42" Vizio tv. Again Kodi 14.2 worked full screen on the Vizio but Kodi 15.0 only give me a small screen on the upper left of the screen. Is there perhaps a video setting in Kodi 15.0 that will fix the problem? Thank you for your support.
debug log (wiki)?
same issue with me. i may have to revert back to 14.x thanks
nevermind...found the fix. disable the amcodec....and it works
system / settings / video / acceleration.....and just untick the amcodec setting. it works now.
On my Amlogic S805 box cs918G plus : disable the amcodec....and it works is true BUT very poor and stuttering image.
i try with last 16.0 alpha? and last 15.1 ..it's exaxtly the same.
I must back to helix 14.2 Sad
You might try http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk (16 alpha) with mediacodec only
I just try that version just now with (16 alpha) with mediacodec only same u said : http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
i try 2 files :
- Full Animation Movie Big Buck Bunny - 3D Animation Short Film HD 60FPS Video.mp4
-1080test.m2ts
I try 1080test.m2ts full screen but It's upscaled 720p. the picture as : http://i.imgur.com/fb6LJJ0.png/
1080test.m2ts works well on Kodi14.2
i try Full Animation Movie Big Buck Bunny - 3D Animation Short Film HD 60FPS Video.mp4 . Stuttering image so much.
Log file :
[MOD EDIT: log removed]
Please use http://xbmclogs.com/ to publish logs
ok sorry Wink
Log file : http://xbmclogs.com/pmz234blx
