Full Version: Channel logo resolution
Hello,
The logos were displayed in Argus TV Scheduler Console and I continued to set up Kodi with the Argus pvr addon.
The channels and logos all pulled in to Kodi, however the logos are now lower resolution than the original .png.
Anyone have any idea if this is happening in Argus or Kodi? Somewhere between the original file and Kodi the logos are being compressed or resized?
e.g.
Did you ever find a resolution to this? I'm having the same problem and can't figure out a way to get full resolution logos except by manually assigning them one by one in Kodi.
Just wanted to post that I ended up resolving this. The biggest problem seemed to be the caching of channel logos at this path: C:\Users\yourusername\AppData\Local\Temp. Deleted those, restarted Kodi and the logos were cached from the higher definition versions. Just be careful to delete only *.png or manually pick your TV logos. Deleting in that folder without attention can yield some serious problems!
