2015-06-29, 14:12
I have noticed that as soon as background is set to true, local images won't get reloaded if they will be replaced another one.
Easy way to reproduce it:
-> Local stored poster.jpg of an movie
-> Remove the movie of the database / drop the source where the movie is in
-> Replace the poster.jpg with another one
-> Readd the movie to you DB/ search for new contents
The old poster.jpg is still in the cache and even a skin refresh/reboot won't help. Only deleting the cached thumbnails manually or trigger a forced refresh via the DialogVideoInfo will cache the new one (btw: shouldn't this be done automatically while rescanning the video source?). Simply choosing the replaced .jpg with the select dialog doesn't help.
I also faced it in some other scenarios, where images of the /extra/ or any other folder were used.
If I remove the background tag of the image control, everything is fine.
Edit:
Forgot to mention -> Isgenard Nightlies
Edit:
