Full Version: [BOBLIGHTD] startup issues
Hi Members,
System:
Kodibunto
2:14.0~git20141223.1015-final-0trusty
Symtoms:
When my kodi starts up Boblightd deamon does not start up automaticly
Workaround:
SSH to kodi and type the following command
boblightd
This is not a good solution for me since i want it to start on system startup
Tried:
I have tired different things wich did not work for me,
I searched this forum and could not find anything about it.
i also search on the interwebs, and could only find this one, wich was not working either
Boblight start up instruktions
I suspect this to be the cause why its not working i think the different places are not the correct onces and therefore its not working for me!:
PATH=/usr/local/bin:/bin:/usr/bin
NAME=boblightd
DAEMON=/usr/bin/$NAME
PIDFILE=/var/run/$NAME.pid
DESC="boblight daemon"
USER=boblightd
If someone could tell me how i could get my boblightd to run at start up, then i would be happy :-)
is there an /etc/rc.local file? If so just add "boblightd &" in there (don't forget the &) and it should start on each boot.
Also having similiar problem
bmw service
Ok i changed the values but there is still no luck
/etc/rc.local
Quote:#!/bin/sh
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
boblightd &
exit 0
I ran this in my rc.local to see if it was working proberly
echo "rc.local executed successfully" > /tmp/rclocal_executed
and the /tmp/rclocal_executed was there so i think the rc.local is runnig as it should
which boblightd
and then put the whole path into there like
/usr/sbin/boblightd &
(or whatever the first command reveals as path of it). Also you might need to pass the boblight.conf file as argument
Ok I added the following in the /etc/rc.local
/usr/local/bin/boblightd -f
After a restart it was working like a charm :-)
I think i would make a Guide/Writeup on how to install boblight, and get some of the basic configure to help simplify it.
anyways thank you for your help Memphiz
