2015-06-30, 10:17
Well i try to build the pvr vdr vnsi addon as far as i know the way it sould be done.
I called cmake in projects/addons like this: cmake -DADDONS_TO_BUILD=pvr.vdr.vnsi .
While here ends the information i went deeper into build(pvr.vdr.vnsi
Then i added a changelog to depends/
Finally i called debuild -us -uc -d
It fails with the following error:
Beside of this i wonder the following things:
1. even though kodi itself defaults for installation prefix to /usr/local why does the pvr.vdr.vnsi addon default to /usr
2. why is the pvr.vdr.vnsi addon not following different prefix configuration given my the correspodning cmake declaration. Other addons follow the configuration but this one has it hard coded at several points.
IBecause of this strange hard coded install prefix i forced kodi to /usr.
I tried building many (not all) of the addons and all build and package fine and follow the install prefiix configuration except pvr.vdr.vnsi.
I would be greatfull if someone can clarify what i'm missing and maybe fix this.[/quote]
Quote:-- Installing: /usr/src/xbmc-stuff/kodi/project/cmake/addons/build/pvr.vdr.vnsi/debian/tmp/usr/share/kodi/addons/pvr.vdr.vnsi/resources/skins/skin.confluence/720p
-- Installing: /usr/src/xbmc-stuff/kodi/project/cmake/addons/build/pvr.vdr.vnsi/debian/tmp/usr/share/kodi/addons/pvr.vdr.vnsi/resources/skins/skin.confluence/720p/Admin.xml
-- Installing: /usr/src/xbmc-stuff/kodi/project/cmake/addons/build/pvr.vdr.vnsi/debian/tmp/usr/share/kodi/addons/pvr.vdr.vnsi/resources/skins/skin.confluence/720p/ChannelScan.xml
make[1]: Leaving directory '/usr/src/xbmc-stuff/kodi/project/cmake/addons/build/pvr.vdr.vnsi/obj-x86_64-linux-gnu'
dh_install
dh_install: kodi-pvr-vdr-vnsi missing files (usr/lib/*/kodi/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.so*), aborting
debian/rules:10: recipe for target 'binary' failed
make: *** [binary] Error 2
dpkg-buildpackage: Fehler: Fehler-Exitstatus von fakeroot debian/rules binary war 2
debuild: fatal error at line 1376:
dpkg-buildpackage -rfakeroot -d -us -uc failed
