Full Version: Pi-DAC+ not available in Kodi
I've upgraded my Raspberry Pi 2 with a Pi-DAC+ (http://iqaudio.com/?page_id=454). I'm using Arch Linux. Playing music with mplayer works fine:
mplayer -nolirc -ao alsa:device=hw=1,0 test.mp3
Kodi is started as user kodi. This user should see the sound card:
[kodi@htpc ~]$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
default:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
sysdefault:CARD=ALSA
default:CARD=IQaudIODAC
    IQaudIODAC,
sysdefault:CARD=IQaudIODAC
    IQaudIODAC,
[kodi@htpc ~]$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
  Subdevices: 1/1
card 1: IQaudIODAC [IQaudIODAC], device 0: IQaudIO DAC HiFi pcm512x-hifi-0 []
  Subdevices: 1/1
However, the sound card is not detected by Kodi. I've uploaded the logfile here: http://xbmclogs.com/pmu8lfunq
Other sound cards like M2Tech Hiface are detected by kodi. One difference is my new DAC is using i2S Interface.
Any help is appreciated. I don't know what to do.
I am using Kodi with Raspbian and the IQAudio DAC+ works fine. If you want to move to Raspbian I could perhaps help by supplying info about my configuration.
Regards
Werner
Have you added "dtoverlay=iqaudio-dacplus" to the config.txt file?
