Full Version: Nightly build is not nightly
I've added the repository as described in the wiki http://kodi.wiki/view/HOW-TO:Install_Kod...ment_build
The wiki says "Use ppa:team-xbmc/xbmc-nightly for nightly builds" but when running apt-get update/apt-get upgrade it installs "kodi-bin 2:15.0~git20150623.0200-95a4fdc-0precise"
11:57:22 T:3078321984  NOTICE: Starting Kodi (15.0-RC1 Git:95a4fdc). Platform: Linux x86 32-bit
11:57:22 T:3078321984  NOTICE: Using Release Kodi x32 build
11:57:22 T:3078321984  NOTICE: Kodi compiled Jun 23 2015 by GCC 4.6.3 for Linux x86 32-bit version 3.2.69 (197189)
11:57:22 T:3078321984  NOTICE: Running on Ubuntu precise (12.04.5 LTS), kernel: Linux x86 32-bit version 3.2.0-86-generic
The package is over a week old. Am I doing something wrong or is the build system broken?
I don’t think packages for nightly ppa are actually being built in a nightly fashion, for what reason idk.
That's confusing... So there are no deb packages available for last nights build?
No - as package builder is on holidays. If you need them, build yourself for the time being.
(2015-07-02, 13:45)fritsch Wrote: [ -> ]No - as package builder is on holidays.
Ah, that's why. I've got it solved by installing a Milhouse build on my Raspberry Pi instead.
Not sure how that relates to the x86 ppa ... but yeah, fine when you are ...
(2015-07-02, 13:45)fritsch Wrote: [ -> ]No - as package builder is on holidays. If you need them, build yourself for the time being.
That explains the delay.
(2015-07-02, 14:48)fritsch Wrote: [ -> ]Not sure how that relates to the x86 ppa ... but yeah, fine when you are ...
I just wanted last nights build. Since I'm lazy, it was simpler for me to get a nightly for the RPi than setting up my own build environment. I just thought that I should share how I solved my issue.
I think the point is you cant get RPI builds on the PPA.
I feel like I'm creating confusion here.
My objective was to test a PR: https://github.com/xbmc/xbmc/pull/7375
Since I'm on a Linux x86 box right now I thought that the quickest way would be to add the nightly ppa. When it turned out that nightly builds was not available for x86 I went on using a build for another platform as the bugfix is platform independent.
Figured it would be something like that but since you never said it...
Did it fix it?
Sometimes it is hard to judge how much (unrelated) information you should share...
And yes, the fix worked.
It wasn’t that unrelated. Glad it worked. mark as solved and enjoy.
