Full Version: Some HEVC files do not work?
Some HEVC files do not work with Isengard Beta 2. For example:
http://www.file-upload.net/download-1066...-_.ts.html
This sample does not play in current nightly either. Not sure if it's a bug in ffmpeg or in Kodi, but re-encoding with ffmpeg works so ffmpeg can parse the file. And the re-encoded file plays fine in Kodi.
What are the chances that the problem is solved in the Isengard Final?
The problem persists in Isengard RC1.
