(2015-10-16, 17:44)BubbleBobble Wrote: [ -> ]Are there hidden options or is there some kind of expert mode? I don't have 'Use Full HDMI modes for 3D' or 'auto framerates' kind of options.
Are you using a Milhouse build? Have you set setttings level to expert?
'Use Full HDMI modes for 3D' is in video/acceleration settings.
(2015-10-16, 18:02)popcornmix Wrote: [ -> ] (2015-10-16, 17:44)BubbleBobble Wrote: [ -> ]Are there hidden options or is there some kind of expert mode? I don't have 'Use Full HDMI modes for 3D' or 'auto framerates' kind of options.
I am using this build.
2133590 (post)
How do i set an expert level? EDIT: I found it. I am an idiot sorry
Don't feel bad... used Kodi for months when I first started and had no idea levels beyond standard even existed
Later tonight i will try 2D and 3D as you asked in an earlier post. One the iso's will be 300 rise of an empire.
I will use these settings:
- #1014
- 1080p/60
- 'sync playback to display'
- 'Support MVC video (full frame 3D)'
- 'Use Full HDMI modes for 3D'
Audio and the rest will be at default.
What to select for hardware acceleration? OMXPlayer or MMAL?
I am not on youtube as a poster so i won't be making a video like you did, but if you need some photos of my projector (for some feedback) than just state them.
OMX disabled, rest of your settings are good. For audio, under Audio output, disable 'Enable passthrough' option, and set 'Number of channels' to 5.1 or 7.1 (whatever you have). I think there's a decode 8-channel option there that should be enabled.
(2015-10-16, 05:52)Milhouse Wrote: [ -> ]@Leopold/@doveman2: The libnfs developer has commented on issue #124 and is asking for a build of libnfs without compiler optimisations. I've uploaded debug-enabled build #1015x which has libnfs built using -O0 instead of -Os (ie. without optimisation). Could you both provide updated crashlogs with this build? Many thanks.
Will do, if I can get it to crash of course, it hasn't done so since the last time.
Any proggress about 3d frame sequential 120Hz?
3D ISO stuttering worse for me (than what I demo'd in video on p.110) with build #1015.
New OpenELEC Jarvis build #1016:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.10 #1 Fri Oct 16 21:03:05 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 11 2015 16:21:59
Copyright (c) 2012 Broadcom
version cdea693c2a4280e4855643dc7840392d915f19b8 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151016210215-#1016-g3f21054 [Build #1016]
# vcdbg log msg 2>&1 | grep DTOK
001743.346: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (3f210547,
changelog) and tip of
XBMC master (e14bdb84,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (82d2a228, ahead +19)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (0f624784), adsp.biquad.filters (0c35df74), adsp.freesurround (cf13262d), asplib (39fe0a71), pvr.argustv (2bf67bb7, +29), pvr.demo (659712a0), pvr.dvblink (4d718970, +19), pvr.dvbviewer (0ca01b1a, +17), pvr.filmon (bea2509b, +21), pvr.hts (6e19f03f), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c, +30), pvr.mythtv (702bda77), pvr.nextpvr (ef36c940, +20), pvr.njoy (cc2c4a69, +16), pvr.pctv (1494bfc1, +18), pvr.stalker (41fb7c42), pvr.vbox (e92c1236, +32), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (ec514227, +23)
- Includes commits from libshairplay, ahead +3
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] rapidjson-01_native-what.patch: Use Kodi version for now
- Include [env] 2fd666ec: VAAPI: Enable EGL
- Include [env] 5bccbe3e: Kodi: Use Limited Range by default
- Include [env] 43f7e22a: Intel: Implement Passthrough-Range
- Include [env] 3688bda4: Mesa: Bump to 11.0.3
- Include [env] 77368091: Mesa: Bump to 11.0.2
- Include [env] compare: Kodi 16 updates
- Include [env] patch: Enable RapidJSON, drop YASL
- Include [env] patch: Enable pvr addons, disable PVR updates
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Disable Realtek WiFi Power Save (RTL8192CU/RTL8192DU/RTL8812AU)
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [pkg] patch: Fix xcode after videoplayer before PR8008
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:7789: [confluence] fix alignment and improve visible conditions on OSD
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:8133: [videodb] Fix TV shows cleaning after 5755573981ca706a82a7ecbbdf5de112a570377a.
- Include [pkg] PR:8196: jsonrpc: expose profile directory in Profiles.GetCurrentProfile/GetProfiles.
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
- Revert [pkg] PR:8212: Add ffmpeg tagloader - retry (Reason: FM VP rebase required)
- Revert [pkg] PR:8216: FFmpeg: Bump to 2.8.1-Jarvis-alpha4-HEVC (Reason: FM VP rebase required)
- Revert [pkg] PR:8227: [win32] Fix VS project after #8212 (Reason: FM VP rebase required)
- Revert [pkg] PR:8234: Save last used eglConfig to m_eglConfig and reuse it wherever is possible (Reason: FM VP rebase required)
Build Highlights:
- Bump sqlite, install sqlite3 binary
- Bump ffmpeg 2.8.1
Build Details:
- OpenELEC:
- (wetek_play) platform_init: Use 1080p virtual size in 720p mode (eda2b9b0)
- (wetek_play) platform_init: Assume SMP uses shared cpufreq policy for all CPUs (8a26958a)
- (wetek_play) update splash (e33754cf)
- sqlite: update to sqlite-autoconf-3090000, install sqlite binary (3f210547)
- XBMC:
- [gui] fix missing path param in CGUIDialog::Open() after 447ec5b (PR:8194, 1 commit, 7 files changed)
- [guilib] add ability to visualize control hitrects (PR:8230, 1 commit, 4 files changed)
- Enable editing of userrating from the frontend (PR:8049, 3 commits, 25 files changed)
- Fix tests after removal of atv2 See: #8181 (PR:8233, 1 commit, 1 file changed)
- Save last used eglConfig to m_eglConfig and reuse it wherever is possible (PR:8234, 1 commit, 1 file changed)
- Reverted: [pkg] PR:8234: Save last used eglConfig to m_eglConfig and reuse it wherever is possible (Reason: FM VP rebase required)
- Updated: [env] compare: Kodi 16 updates
For me 3D is working out great. I had no stuttering whatsoever. Frame packing at 1080p/23.97 and it goes as smooth as my stand alone bluray players.
One time i had a out-of-sync but that sometimes happened on other sources as well so i don't dare to blame it on my Raspberry.
I have a problem with subtitles though. Every now and then the font is really large and shown half on the screen.
Picture quality is amazing! I can see no difference between my pricey Oppo 93
Damn, seems like the RPi has fried another of my USB sticks. All the Windows tools I've tried to scan it just report the blocks are unreadable and can't reformat it.
This is the second stick that's died in my RPi's. The first had more use as I was using it for the /storage partition but this one I've barely used, as I only had it to record TV programmes onto and tvheadend isn't working for me most of the time. I haven't had any of my other sticks that I only use with PCs die, even though they're much older.
Oh well, I haven't got any need to use one with the RPi at the moment. If I ever get tvheadend working reliably, I'll have to look at recording to the SD card or a shared folder on my PC, although I'd rather avoid having to have the PC on when recording.
The Wetek splash screen is so much nicer, can we get a nicer one for the RP1/2 too?
I had to reformat my SD to install debug #1015x so backed up .kodi first. After installing it manually, I booted and went through the initial setup, then copied my backup files back to the SD.
Now I can't access tvheadend through the browser interface on
http://192.168.1.85:9981/ at all. I've made sure only tvheadend backend and client are enabled and rebooted but it just says page not found.
http://192.168.1.85/ opens the Kodi interface, so the address is right. dmesg shows the tuner is recognised and initialised.
http://pastebin.com/cG7hmLMD
Doesn't tvheadend have it's own log? Is tvheadend listening on port 9981? Does tvheadend work with #1015 (the only difference between the two builds should be the way libnfs is compiled)?
There is a new tvheadend in the addons folder
http://milhouse.openelec.tv/builds/addons/
(2015-10-17, 01:23)OurJermain Wrote: [ -> ]The Wetek splash screen is so much nicer, can we get a nicer one for the RP1/2 too?
Hard to find fault with something I rarely ever see, but this should be discussed separately in a new thread here or on the OE forum as the splash we use in these builds is unchanged from official releases.
