Version : 1024 (also tested on 1023)
Tested on : 2 seperate RPI2's
Database : MySQL
Directory Structure Example :
Action > Movie1.mkv
Movie2.mkv
Adventure > Movie1.mkv
Movie2.mkv
I have my movies organised in genre folders.. if i delete a movie from a folder and then clean the database, it seems like it removes all the movies in that genre folder from the database... not just the one i deleted..If i then update the library it adds back in the ones that are still there...
Any ideas?
Edit : Here's the log file for the relevant CleanDatabase command :
http://xbmclogs.com/pg9acwgas
Edit : I just tried it on the Windows build of 16 and it does not appear to do it on that..
(2015-10-25, 13:46)popcornmix Wrote: [ -> ] (2015-10-25, 11:53)movie78 Wrote: [ -> ]The new update option doesn't work well, so i went back to Build #1021
Too much steps just to play a movie and none of my 3D ISO plackback in 3D,unless i Enable 3D in player Menu.
I watched Edge of Tomrorrow yesterday with #1023 and it was perfect. I assume you have "Support MVC video (full frame 3D)" enabled in video/acceleration settings?
You'll need to provide more details if you want your problem resolved. A debug log (wiki) when playing a file would be a good start.
I also tested it with my one and only 3D blu-ray and it worked just fine. The only think that didn't not work correctly was resuming, as it resumed in 2D, but that's a know issue.
movie78 - if you want stuff to be 3D by default you have to change your preferred playback mode to 3D in Settings -> Video -> Playback.
(2015-10-25, 18:32)da-anda Wrote: [ -> ]I also tested it with my one and only 3D blu-ray and it worked just fine. The only think that didn't not work correctly was resuming, as it resumed in 2D, but that's a know issue.
That should be fixed in latest builds (and worked for me). A debug log would be useful if latest build is not working for you (perhaps you are getting a filename I'm not expecting).
(2015-10-25, 17:18)danmedhurst Wrote: [ -> ]I have my movies organised in genre folders.. if i delete a movie from a folder and then clean the database, it seems like it removes all the movies in that genre folder from the database... not just the one i deleted..If i then update the library it adds back in the ones that are still there...
Milhouse looks like my PR to fix TV show cleaning (#8133) causes problems with multiple movies in the same folder, you may want to drop it from next build.
@menakite: Will do, thanks.
New OpenELEC Jarvis build #1025:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.11 #1 Sun Oct 25 21:58:33 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Oct 23 2015 16:28:38
Copyright (c) 2012 Broadcom
version c1a8b643677011791abeea1f5dc3a4738349ea55 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151025215709-#1025-g2813f9d [Build #1025]
# vcdbg log msg 2>&1 | grep DTOK
001724.497: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (2813f9d9,
changelog) and tip of
XBMC master (c524791a,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (df5c386d, +1), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (a7fa1d65), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (e088636e, +9), pvr.nextpvr (ef36c940), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (41fb7c42), pvr.vbox (e92c1236), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Exclude [env] kodi-999.31-PR7916.patch: Merged upstream
- Exclude [env] kodi-999.51-nonX11-mousewheel-support.patch: Merged upstream
- Exclude [env] kodi-999.52-multitouch-support.patch: Merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Include [env] cec3c4f5: Intel: Passthrough Mode - little workaround
- Include [env] fbaeb593: Intel: Implement Passthrough-Range
- Include [env] 3cf87d45: Kodi: Use Limited Range by default
- Include [env] 6ad7a2cd: VAAPI: Enable EGL
- Include [env] 7f8f12f6: mesa: bump mesa to 11.0.4
- Include [env] 46a038e6: Intel: Automatically switch to full range
- Include [env] 87eaaa2f: Python: update to Python-2.7.10
- Include [env] 92db150e: systemd: update to systemd-227
- Include [env] patch: Disable Realtek WiFi Power Save (RTL8192CU/RTL8192DU/RTL8812AU)
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Add experimental splash video
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [env] PR:4384: Kodi 16.0 Jarvis
- Include [env] PR:4398: Add amdgpu support
- Include [env] PR:4399: [RBP] Drop mkknlimg, use version shipped with kernel
- Revert [env] 9da7df25: Already disabled by systemd-227 bump
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
- Revert [pkg] PR:8277: ADD: [droid] surface rendering mediacodec (Reason: Needs newclock5/FernetMenta rebase)
- Revert [pkg] PR:8278: [droid] fix crashing on addon installation (Reason: Needs newclock5/FernetMenta rebase)
- Revert [pkg] PR:8285: [cleanup] remove karaoke support (Reason: Needs newclock5/FernetMenta rebase)
Build Highlights:
- New kernel 4.1.11
- Bump busybox
- Drop PR8133 due to problems when cleaning database
- Revert PR8277, PR8278 and PR8285 - needs newclock5 rebase
- Temporarily drop "Hide watched for home screen widget" commits - conflict with PR6024
Build Details:
- OpenELEC:
- busybox: update to busybox-1.24.1 (2813f9d9)
- XBMC:
- [droid] fix crashing on addon installation (PR:8278, 2 commits, 5 files changed)
- [videos] default to play select action in case there's no information… (PR:8284, 1 commit, 1 file changed)
- Fix music navigation generic content "songs" setting (PR:8287, 1 commit, 1 file changed)
- [pvr] reset changed flag for channels after storing them to db (PR:8199, 1 commit, 3 files changed)
- [cleanup] remove karaoke support (PR:8285, 1 commit, 62 files changed)
- texturepacker cosmetics (PR:8251, 2 commits, 2 files changed)
- jsonrpc: fix type parsing warnings (PR:8265, 1 commit, 1 file changed)
- Fixed crash on scanning incomplete id3v2 tags (PR:8195, 3 commits, 3 files changed)
- [settings] Promote hideemptyseries to GUI setting. (PR:6024, 1 commit, 7 files changed)
- FIX: [droid] increase valid refresh rate limits (PR:8292, 1 commit, 1 file changed)
- CGUIDialogAudioDSPSettings: fix duplication of "Are you sure?" in dialog message: (PR:8293, 1 commit, 1 file changed)
- [confluence] add full screen button to PVR (PR:8295, 1 commit, 2 files changed)
- [infomanager] fix possible crash when accessing ListItem.UserRating (PR:8286, 2 commits, 1 file changed)
- asplib:
- [asplib_utils] Add missing GPL header to IPortAudio (df5c386d)
- kernel 4.1.y_rebase:
- New commits in this build:
- rpi_display: add backlight driver and overlay (d83e5738)
- rtl8192c_rf6052: PHY_RFShadowRefresh(): fix off-by-one (38e29d88)
- bcm2835-gpiomem: Fix for ARCH_BCM2835 builds (215c9d16)
- BCM270X_DT: Add at86rf233 overlay (965983e3)
- New overlay for PiScreen2r (c13e8e72)
- BCM270X_DT: Make mmc overlay compatible with current firmware (c5f71245)
- BCM270X_DT: Reduce default at86rf233 SPI frequency (c8dd26a1)
- config: Add CONFIG_UHID (a3e2d5a2)
- config: Add CONFIG_CRYPTO_USER_API_SKCIPHER (b965d6e4)
- config: Add options for supporting openlabs 802.15.4 radio (1fa8f525)
- scripts/mkknlimg: Improve ARCH_BCM2835 detection (da45ab9f)
- Added: [env] 7f8f12f6: mesa: bump mesa to 11.0.4
- Added: [env] PR:4399: [RBP] Drop mkknlimg, use version shipped with kernel
- Reverted: [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
- Reverted: [pkg] PR:8278: [droid] fix crashing on addon installation (Reason: Needs newclock5/FernetMenta rebase)
- Reverted: [pkg] PR:8285: [cleanup] remove karaoke support (Reason: Needs newclock5/FernetMenta rebase)
Typical! A couple of days after updating from #1015x to #1022 I got a libnfs-related crash.
It seemed to be triggered by my rebooting from Win 8.1 to Win 10, where only the former has Hanewin NFS Server installed. If it would be useful I could try going back to #1015x (or a newer debug build if you want to make one) to try and trigger the crash the same way.
Anyway, the crashlog is here:
https://drive.google.com/file/d/0B1fDI89...sp=sharing
I've uploaded the log from after it rebooted as well, just in case it shows anything useful as the NFS server wasn't available then either:
Ah yes, sorry forgot to reply to you both on this - so presumably if there are no crashes after a week with #1015x, then it's possible that disabling the compiler optimisations has actually fixed (or avoided) the problem. I need to add a comment on the libnfs github.
Edit: Just looking at your #1022 crashlog, that doesn't appear to be strictly libnfs related - it seems to be a problem with Python and/or vfs, but it is doing something with NFS at the time of the crash. I wonder if the "nfs_service failed" issue that precedes the crash by 2 hours is related.
(2015-10-26, 04:38)Milhouse Wrote: [ -> ]Just looking at your #1022 crashlog, that doesn't appear to be strictly libnfs related - it seems to be a problem with Python and/or vfs, but it is doing something with NFS at the time of the crash. I wonder if the "nfs_service failed" issue that precedes the crash by 2 hours is related.
Hmm, possibly. I haven't used the Pi today so I don't know if the NFS server had a problem but the PC it's running on was up all day until I rebooted to Win 10.
My experience with the actual developer release is very pleasant.
I switched from 5.95.5 and try to keep it as a rolling release and do updates as much as possible. Sometimes it happen that I have some strange behaviors with the live-tv which will gone when I do a clean install again. So maybe it could also be a good advice for some other testers to do a clean install from time to time.
Does someone know if there is an easy way for just clean up settings an keep add-ons? Can I just delete "/storage/.kodi/userdata/"?
(2015-10-26, 23:53)herrmeier01 Wrote: [ -> ]My experience with the actual developer release is very pleasant.
You can use the built in Openelec addon to backup and restore your installation. There is also a setting to do a soft reset which I assume just deletes the userdata folder.
http://wiki.openelec.tv/index.php/OpenEL...tion_Addon
New OpenELEC Jarvis build #1026:
RPi /
RPi2
# uname -a
Linux rpi512 4.1.11 #1 Mon Oct 26 21:05:30 GMT 2015 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151026210440-#1026-g2813f9d [Build #1026]
001726.044: Kernel trailer DTOK property says yes
Based on tip of
XBMC master (6b91ddee,
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (df5c386d, +1), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (e14678a2, +3), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (e088636e, +9), pvr.nextpvr (d30604cb, +1), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (41fb7c42), pvr.vbox (e92c1236), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Revert [pkg] PR:8294: CHG: [droid] stop video when loosing focus (Reason: Needs newclock5/FernetMenta rebase)
Build Highlights:
- Prefer CEA modes to DMT when probing
Build Details:
- XBMC:
- [confluence][3D] random improvements to stereoscopic depth of elements (PR:8289, 1 commit, 5 files changed)
- [Screensaver] Allow Dim screensaver to animate when closing (PR:8297, 1 commit, 2 files changed)
- CHG: [droid] stop video when loosing focus (PR:8294, 2 commits, 2 files changed)
- FIX: [droid] also check CPU2 for compatibility (PR:8299, 1 commit, 1 file changed)
- CHG: [droid] Use best possible icons for app + refactor (PR:8300, 1 commit, 17 files changed)
- pvr.hts:
- Add support for streaming profiles (PR:119, 3 commits, 12 files changed)
- pvr.nextpvr:
- Improved support for Jarvis timers and TV Guide artwork (PR:28, 1 commit, 7 files changed)
- newclock5:
- [rpb] Change order or CEA and DMT mode probing so CEA modes are preferred (9ca82a41)
- [pisink] testing: Reduce audio output latency to 50ms (fd06005e)
- Reverted: [pkg] PR:8294: CHG: [droid] stop video when loosing focus (Reason: Needs newclock5/FernetMenta rebase)
Jdiesel Thanks you for your help.
The soft reset delete the add-ons too. But anyway maybe it's a good idea to clean up everything to be sure not keep any inconsistencies.
audio seems off on the latest build - will have to do more testing from some non streamed sources but haven't seen this before.
Hello,
is it possible to play .mk3d or something like this ? MKV with full frame like a ISO 3D.
MK3D is the best because we can rip BR3D without re-encode the file. It support AVC+MVC format.
I try .mk3d but Kodi (through my Pi 2) play it in 2D.
Thank you.
