It tells something about missing dependencies and lists about every skin installed (except Confluence I think).
(2015-11-15, 01:22)Milhouse Wrote: [ -> ]@popcornmix/@HiassofT: So is this a bug in the i2s driver (that is triggered by PR:4411), or is it a bug only in PR:4411? Or is there a problem in both the driver and PR:4411?
These are 2 separate issues.
The bug in PR:4411 causes some alsa devices no longer to show up in kodi. This happens both with snd_bcm2835 (onboard analog audio, so it's quite easy to reproduce on a stock RPi) and I2S cards. Most likely the line mentioned by popcornmix causes this.
The backtrace in the kernel log when closing an I2S device is a different thing. It's most likely harmless, but still should be fixed. notro already had an idea for a fix:
https://github.com/raspberrypi/linux/pul...-156745629
BTW: build 1114 is fine, both snd_bcm2835 and the iqaudio dacplus i2s card show up in kodi again.
so long,
Hias
Milhouse. I agree with HassofT's reading of the issue. Can you include PR:4411 in tonight's build but reinstate the suspiciously removed line:
EnumerateDevice(list, "default", "", config);
just to confirm if it is exactly that line.
(2015-11-15, 13:46)Cy4n1d3 Wrote: [ -> ]It tells something about missing dependencies and lists about every skin installed (except Confluence I think).
You'll need to contact the skin authors. If there's a bug then fine, we can see if there's a fix, but if the skins are no longer compatible (see PR8239 introduced in build #1101) then they now need updating to be considered "Kodi 16 compatible".
HD live TV seems much improved
I'm using #1113 and I'm not seeing any green pixelation or stuttering with advanced deinterlace. My backend is on a separate Pi though.
(2015-11-15, 21:35)Leopold Wrote: [ -> ]HD live TV seems much improved
Can you identify when this happened?
It was possibly with 1111b which increased the usb priority compared to deinterlace code, but it would be nice to confirm if that is definitely the case.
Is there any chance to give a rough estimate when libaacs support will come back?
(2015-11-15, 22:26)nalor Wrote: [ -> ]Is there any chance to give a rough estimate when libaacs support will come back?
What problem are you experiencing with libaacs disabled - are you trying to play encrypted disks directly from optical media?
New OpenELEC Jarvis build #1115:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.0 #1 Sun Nov 15 21:02:47 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 11 2015 21:36:20
Copyright (c) 2012 Broadcom
version 54011a8ad59a9ae1c40bd07cddd9bcf90e779b66 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151115210151-#1115-g60c4d40 [Build #1115]
# vcdbg log msg 2>&1 | grep DTOK
001690.718: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (60c4d40d,
changelog) and tip of
XBMC master (8b6a4b80,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (57012a4b, ahead +42)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2c675dac, ahead +6)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (df5c386d, +1), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (0774d6fd, +6), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (e088636e), pvr.nextpvr (b902321f), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (9a6d06e2, +7), pvr.vbox (e92c1236), pvr.vdr.vnsi (5eba8692, +36), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Includes commits from xbmc/json-profile-directory_2, ahead +2 (anaconda)
- Exclude [env] bcm2708-rng.conf: No longer required
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.60-udevprovider-fix-mounting-raw-filesystems.patch: Already merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] d3a99d6c: ffmpeg: update to ffmpeg-2.8.2
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Build fix
- Include [env] patch: Fix PR4411 PulseAudio/i2s breakage
- Include [env] patch: ARCH_BCM270X: Drop ATAGS support, https://github.com/raspberrypi/linux/pull/1178
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Add experimental splash video
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Include [pkg] PR:8356: Fix inversion of export library dialogs, fix #16317, fix #16358
- Revert [pkg] PR:8382: FIX: [amc] skip frame render when changing surface size (Reason: Requires VideoPlayer rebase)
- Revert [pkg] PR:8383: FIX: [droid] Only sw for SD MPEG (Reason: Requires VideoPlayer rebase)
- Revert [pkg] PR:8384: [amcodec] partialy revert 344af8f (Reason: Requires VideoPlayer rebase)
Build Highlights:
- Kodi 16.0 beta 2
- Bump to ffmpeg 2.8.2
- Restored PR:4411, dropped first hunk from first commit
Build Details:
- XBMC:
- bump to 16.0 beta 2 (PR:8387, 1 commit, 1 file changed)
- [repo] Only fetch the addons.xml for the current version (PR:8388, 1 commit, 1 file changed)
- FFMpeg: Bump to 2.8.2-Jarvis-beta2 (PR:8391, 1 commit, 1 file changed)
- pvr.hts:
- Fix WIN32 build breaker (added missing include for std::min) (PR:137, 1 commit, 2 files changed)
- Added: [env] d3a99d6c: ffmpeg: update to ffmpeg-2.8.2
- Added: [env] patch: Fix PR4411 PulseAudio/i2s breakage
(2015-11-15, 23:12)Milhouse Wrote: [ -> ]What problem are you experiencing with libaacs disabled - are you trying to play encrypted disks directly from optical media?
I'm trying to play encrypted iso files in 2D (this worked in the past without problems) and 3D if possible.
But just for interest I could really try to play discs also directly from optical drive
(2015-11-16, 00:00)nalor Wrote: [ -> ]I'm trying to play encrypted iso files in 2D (this worked in the past without problems) and 3D if possible.
It's being looked into, but on Pi the number of users of encrypted optical disks is probably a lot less than users of unencrypted ISOs, so unless there's a fix I'm not sure it will be back any time soon.
(2015-11-16, 06:46)illiac4 Wrote: [ -> ]Since build 1103 this commit is applied https://github.com/fritsch/OpenELEC.tv/c...de08404cca which causes that PVR groups are not synchronized with backend. What is the point of this or is it just a bug?
I've no idea. Ping @
fritsch.
Edit: I see you've asked on github
PR:4414 and that's the best place for this discussion (no need having it in two places).
(2015-11-15, 23:54)Milhouse Wrote: [ -> ][*]Restored PR:4411, dropped first hunk from first commit
Anyone with i2s/hifiberry issues can they please confirm the situation after #1115, thanks.
Edit: Also, is the "passthrough output device" option enabled in #1115, or does it remain greyed out?
