(2015-11-16, 00:00)nalor Wrote: [ -> ]I'm trying to play encrypted iso files in 2D (this worked in the past without problems) and 3D if possible.
But just for interest I could really try to play discs also directly from optical drive
Is this currently working on OE 6.0? That does have libaacs.
Is it slower to start playback of encrypted ISOs?
Logically it would make more sense to remove the encryption when ripping the ISO rather than trying to remove it every time you play the ISO (potentially needing decryption support on multiple devices).
I would be interested if you can play straight from an optical BlueRay drive (either locally attached or from a network share). Don't think I've heard of that working (except from a network share from a PC running anydvd or similar to remove the encryption).
(2015-11-16, 10:08)Milhouse Wrote: [ -> ]Anyone with i2s/hifiberry issues can they please confirm the situation after #1115, thanks.
Edit: Also, is the "passthrough output device" option enabled in #1115, or does it remain greyed out?
Everything's looking fine, both snd-bcm2835 and the iqaudio card show up and I can select passthrough on a USB card with spdif. Can't test though if passthrough actually works, but I assume it will.
Thanks a lot!
so long,
Hias
Quick Q- does nightly 1015 use the same video and music library as beta 1?
(2015-11-16, 14:39)HiassofT Wrote: [ -> ] (2015-11-16, 10:08)Milhouse Wrote: [ -> ]Anyone with i2s/hifiberry issues can they please confirm the situation after #1115, thanks.
Thanks a lot!
so long,
Hias
Thanks HiassofT.
I also have a better explanation of why this only became an issue once we dropped PulseAudio: #4427 (which added the Alsa/Pulse Bridge) reverts the enumeration part of #4411, so dropping #4427 exposed this enumeration issue. Not sure when #4427 will merge but apparently most of #4411 is unnecessary so hopefully that will be fixed first.
I suspect #4427 will still cause passthrough device problems, so that's an issue yet to be fixed. For now I'll continue to revert #4411, and leave out #4427 until there is more progress.
(2015-11-16, 18:02)steve1977 Wrote: [ -> ]Quick Q- does nightly 1015 use the same video and music library as beta 1?
Yes - videodb v99, musicdb v56.
Interesting, now I only need a generic OpenElec. It's nice to have central MySQL database, but having one client on Kodibuntu, one on Windows, one OpenElec and one Raspberry pi makes it a hassle to upgrade
Just installed #1115 over #1114 and with this update lost a number of confluence settings i.e. GUI sounds back on and change from UK to US international settings, Live TV missing requiring re-enable of options in settings. Don't know how helpful this log file is, as I created it after a changing settings and doing a reboot to see if the changes were stored? (which seems to be the case)
http://sprunge.us/cBXI
Additionally I have been keeping upto date with the recent TVHeadend backend updates (i.e switched to #1115-milhouse-v4.1-990-g2afa831 from previous #1111b-milhouse-v4.1-960-gbafa612) and noticed with combination of this and this #1115 release, that Kodi does not want to let me use my local tv channel icons. (option greyed out in TV menu / osd setting)
other user settings do not seem to have been modified....
-----edit-----
Apologies, just realised that system had changed interface settings from expert to standard between the #1114 to #1115 so actually TV icon option was still available once switching back to expert (but I needed to re-link to folder where icons were stored etc)
New OpenELEC Jarvis build #1116:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.0 #1 Tue Nov 17 04:29:01 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 11 2015 21:36:20
Copyright (c) 2012 Broadcom
version 54011a8ad59a9ae1c40bd07cddd9bcf90e779b66 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151117042807-#1116-g91bbead [Build #1116]
# vcdbg log msg 2>&1 | grep DTOK
001707.012: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (91bbead5,
changelog) and tip of
XBMC master (07f691e6,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (28f7c2ad, ahead +49)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2c675dac, ahead +6)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (df5c386d, +1), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (0774d6fd, +6), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (e088636e), pvr.nextpvr (b902321f), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (9a6d06e2, +7), pvr.vbox (e92c1236), pvr.vdr.vnsi (5eba8692, +36), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Includes commits from xbmc/json-profile-directory_2, ahead +2 (anaconda)
- Exclude [env] bcm2708-rng.conf: No longer required
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.60-udevprovider-fix-mounting-raw-filesystems.patch: Already merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] d3a99d6c: ffmpeg: update to ffmpeg-2.8.2
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: Build fix
- Include [env] patch: ARCH_BCM270X: Drop ATAGS support, https://github.com/raspberrypi/linux/pull/1178
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Add experimental splash video
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [env] PR:4441: Use pkg-config mechanism to synchronize compile flags and paths between VDR and VDR plugins instead of tons of patches.
- Revert [env] PR:4411: various pulseaudio fixes (Reason: Breaks i2s, unnecessary)
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Include [pkg] PR:8356: Fix inversion of export library dialogs, fix #16317, fix #16358
- Include [pkg] PR:8393: [MySQL] Disable ONLY_FULL_GROUP_BY per session
Build Highlights:
- VideoPlayer rebase
- Revert PR:4411. Leave PulseAudio out until passthrough device is fixed.
- Fix MySQL 5.7.5+ incompatability
Build Details:
- OpenELEC:
- linux x86_64: build btrfs into kernel (PR:4444, 1 commit, 2 files changed)
- libressl: update ca-cert bundle (PR:4442, 1 commit, 3 files changed)
- pciutils: fix pkgconfig patch (22713800)
- XBMC:
- Support PlayingBackgroundMedia In Confluence (PR:8363, 1 commit, 3 files changed)
- dcadec:
- Disallow one sample per XLL segment. (be45b3a5)
- Implement interpolation of downmix coeffs. (8a8e8300)
- Add support for external error logging. (b49c3f89)
- Log more error conditions. (9fce4c6f)
- Make XLL non-losslessness warning more quiet. (4efd8697)
- Refactor hierarchial downmix code. (d287b749)
- Mark downmix coeff validity per channel set. (28f7c2ad)
- newclock5:
- New commits in this build:
- AE: refactor AEStreamInfo and remove some bullshit coding style (3f440063)
- Commits no longer in build:
- AE: fix GetDelay - only apply time correction to sink delay (4bf28b09)
- Added: [env] PR:4441: Use pkg-config mechanism to synchronize compile flags and paths between VDR and VDR plugins instead of tons of patches.
- Reverted: [env] PR:4411: various pulseaudio fixes (Reason: Breaks i2s, unnecessary)
- Added: [pkg] PR:8393: [MySQL] Disable ONLY_FULL_GROUP_BY per session
(2015-11-16, 10:08)Milhouse Wrote: [ -> ] (2015-11-15, 23:54)Milhouse Wrote: [ -> ][*]Restored PR:4411, dropped first hunk from first commit
I can confirm with Hifiberry Digi+ that passthrough works on #1115. However I have an issue that AC3 and DTS are not detected on my receiver using SPDIF which worked at least partly on OE 6.0. Means DTS was detected and AC3 not.
ok - here i am ... with #1116: RPi2
____________________________
First RPi2 with Hifiberry-DAC+ :
AudioCD DTS5.1 will work fine , for me is that ok. ;-)
with passtrough there is no sound [?] ...
the same on DD5.1 - the DAC makes his job .[no passtrough].
_____________________________________________________________
Second RPi2 over HDMI and SPDIF(optical) - Audio to Yahama Receiver:
Audio CD DTS5.1 - great Sound with passtrough!
Video, here with an Depech Mode live concert - DD5.1 [AC3) over SPDIF (optical) and passtrough also perfect sound on my Yamaha Receiver.
I think, the people here makes a very good Job
SeeYaah :-)
Edit: @ Ollo -> if i deaktivate passtrough over HDMI / SPDIF the sound is only "Stereo" ...think also normaly.
@ Milhouse: there is a "Buffering", 3 seconds when i'm switching - in older builds i would not notice this ... no prob for me.
1115 worked for my hifiberry. Haven't tried passthrough yet.
(2015-11-17, 18:58)Ollo Wrote: [ -> ]However I have an issue that AC3 and DTS are not detected on my receiver using SPDIF which worked at least partly on OE 6.0. Means DTS was detected and AC3 not.
If you can identify the first build here that changes the DTS/AC3 SPDIF behaviour, then it will help a lot.
Hi, I still have no sound with 1:1 3d.ISO files.
example: edge of tomorrow, framepacked 3d with DTS-HD MA
older versions (1106 for example) are able to play this image in 2d with sound, but not in 3d...
I'm using multichannel 5.1 PCM decoding to my preamp for all HD audio codecs
(2015-11-18, 02:08)motorherz Wrote: [ -> ]Hi, I still have no sound with 1:1 3d.ISO files.
Has it always been like this, with 3D? What about the official OpenELEC 6.0 release - sound with 2D and 3D? If you can identify the build when the 3D audio stops, that would be good to know...
New OpenELEC Jarvis build #1117:
RPi /
RPi2
# uname -a
Linux rpi512 4.3.0 #1 Tue Nov 17 22:15:37 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 17 2015 11:59:09
version 479d08154398621494e6f12770f4b68b663c2267 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151117220546-#1117-gad1a200 [Build #1117]
001710.507: Kernel trailer DTOK property says yes
Based on tip of
OpenELEC master (ad1a2005,
- Includes latest dcadec master (9c22dd45, ahead +51)
Build Highlights:
- OpenELEC 7.0
- New firmware
- VideoPlayer (newclock5) updates, please report any audio regressions, particularly if you're a passthrough user
Build Details:
- Firmware (Nov 17):
- firmware: usb: Reduce usb priority to 13 and di_adv priority to 12
- OpenELEC:
- libtirpc: update to libtirpc-1.0.1 (10bdc708)
- rpcbind: add upstream patch (cd34ab0a)
- config/version: set OS_VERSION to 7.0 (93f58221)
- mesa: update to mesa-11.0.5 (b1ddbc41)
- ffmpeg: update to ffmpeg-2.8.2 (e5a71f28)
- fuse-exfat: update to fuse-exfat-1.2.2 (b35878f5)
- libevdev: update to libevdev-1.4.5 (cd7766e2)
- libevdev: update to util-linux-2.27.1 (40300a7a)
- libinput: update to libinput-1.1.1 (ac6043c7)
- libmicrohttpd: update to libmicrohttpd-0.9.46 (e769a89e)
- xkbcomp: update to xkbcomp-1.3.1 (4043965c)
- xkeyboard-config: update to xkeyboard-config-2.16 (ee30a2fa)
- xf86-video-ati: update to xf86-video-ati-7.6.1 (352dc434)
- pixman: update to pixman-0.33.4 (d05fda59)
- pycrypto: update to pycrypto-2.6.1 (8293c1c0)
- xorg-server: update to xorg-server-1.18.0 (e5e95515)
- xorg-server: add patch to add prime support (from fedora) (ad1a2005)
- dcadec:
- Make interpolation of downmix coeffs more robust. (9446d0ba)
- Track core residual mode validity more carefully. (9c22dd45)
- newclock5:
- renderer: fix forced deinterlacing for non-render methods (d50cd634)
- AE: test type of stream for passthough modes (ae275060)
- omxplayer: fixup: AE: test type of stream for passthough modes (b881d986)
- AE: add raw stream info to AEAudioFormat (cc90bb1d)
- AE: drop encoded sample rate (b488d90b)
- AE: pass entire AEAudioFormat to MakeStream (6099c4a3)
- [pvr] Add progress bar with timeshift progress when timeshift is active (5c0eef7c)
