(2016-02-22, 16:34)Deano316 Wrote: [ -> ]I currently run a Pi 2 on OpenELEC 6 using the stable release (15.2), currently I get 7.1 TrueHD through PCM but only DTS 5.1. Also I don't have 3D isos displaying correctly. Can anyone confirm whether these are working on the latest nightly?
3D ISO is
Milhouse nightly only.
Note: this thread is dead. There won't be any more Milhouse Kodi 16 test builds.
Milhouse test builds are now Kodi 17.
(2016-02-22, 16:40)popcornmix Wrote: [ -> ] (2016-02-22, 16:34)Deano316 Wrote: [ -> ]I currently run a Pi 2 on OpenELEC 6 using the stable release (15.2), currently I get 7.1 TrueHD through PCM but only DTS 5.1. Also I don't have 3D isos displaying correctly. Can anyone confirm whether these are working on the latest nightly?
3D ISO is Milhouse nightly only.
Ok, I'll give that a try, thanks for the response
Edit: Worked like a charm.
(2016-02-19, 05:20)whiffyfuzzball Wrote: [ -> ]To save anyone else looking back pages for the last Kodi 16 test build, it's here: http://forum.kodi.tv/showthread.php?tid=...pid2178552
Question, is the build above the best build to run on my raspberry pi at this time that includes jarvis?
Thank you
It certainly worked at the time, so should work now. Work is progressing towards an official OpenELEC 7.0 Jarvis release
Do you know if there are any blocking points/issues this time like there were with 6.0.0, or is it just a case of it's taking a little time to get everything done and right and patience needed?
There are some blockers, yes. One of them being a Python issues that has hopefully been resolved today.
I am having issues pairing my device (rpi2) with the 1204 build - this is the first time I am trying this so I am not sure what the issues are - my bluetooth adapter is an ASUS adapter (BCM20702A0 Broadcom based). I can detect my headphones (ankerSoundbuds) - but when I pair them, it says connected for a few seconds then says file "Bluetooth Error - no such file or directory".
Not sure what to do here - any help would be great.
Are we talking days, weeks or months until OpenELEC is officially released with "Jarvis"?
Can anyone recommend a reputable source to get a current build of OE7 ? This seems to be oddly lacking to my searching.
I'm thinking of testing #1204 from 6.0.1, just curious if anyone has any feedback before I switch.
If I have any issues, can I revert back back to 6.0.1 ?? If yes what is the best way to do so, cheers.
Thanks Millhouse for all the great work
Yes. Just drop the 6.0.1 tar file in the Update folder and reboot.
(2016-03-03, 14:48)Milhouse Wrote: [ -> ]Yes. Just drop the 6.0.1 tar file in the Update folder and reboot.
Thanks bud, appreciate it, cheers
Installed I'll test it for a few days and report back
I'm running my own compiled build from the master git on Kodi 16.0 (Jarvis) is there a way to upgrade this to the Kodi 16.1 RC1 version?
