Now here is another debug. This time it is with deinterlacer on and as method is selected Bob. This time the video just freezes (stays on one frame) if i press stop this time it stops the video and if i select play it plays again (does not freeze the gui as in other way and othe debug).
http://pastebin.com/LMrFWYVy
P.S.:
After some testing it seems the following:
If I have deinterlacer on and auto as deinterlaced method it freezes after some time with complete freeze as Milhouse has.
If I select deinterlacer on and MMAL Bob as method the picture freezes after some time with video freeze but can stop it and select it once again and it plays again. so without gui freeze,
If I deselect deinterlacer so off, then there are not freezes.
ATM I have those overclocking with 50 celsius temp. With next test i will use default settings and will repeat the tests but i have a strong feeling that it has something to do with deinterlacers.
gpu_mem=320
arm_freq=1000
core_freq=500
over_voltage=4
gpu_freq=400
v3d_freq=300
avoid_pwm_pll=1
force_turbo=0
One question: What does force_turbo in your MMAL code did (Milhouse or. Popcorn) when you were calling deinterlacer? Does selecting deinterlacer causes any frequency change?
Is it possible to create a build that it would actually use default clock settings if any deinterlace method is selected. I am getting feeling that deinterlacer method is very sensible to overclocking. This would maybe explain the behaviour that Milhouse is getting freezes because he uses force turbo 1 and popcornmix not.
Mahhh another kodi crash this time without overclock but from the log it seems different. I am slowly loosing ideas.
http://pastebin.com/rRpxjknw
New OpenELEC Jarvis build #0801:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.3 #1 Sat Aug 1 21:02:55 BST 2015 armv6l GNU/Linux
# vcgencmd version
Jul 30 2015 17:56:23
Copyright (c) 2012 Broadcom
version 065d51651eeaced58522f5591150b64cacdc00f8 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150801210206-#0801-g2fa61b7 [Build #0801]
# vcdbg log msg 2>&1 | grep DTOK
001569.754: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (2fa61b78,
changelog) and tip of
XBMC master (3209de61,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (33b6390b, ahead +1)
- Includes latest libcec master (d997b9aa, ahead +28)
- Includes latest libnfs master (68941809, ahead +25)
- Includes latest platform master (278828aa, ahead +2)
- Includes latest addons: adsp.basic (da6ee5dd), adsp.biquad.filters (b6a31a90), adsp.freesurround (4dd3202f), asplib (490de460), pvr.argustv (b5fef151, +22), pvr.demo (bb2c46a6, +13), pvr.dvblink (65073157, +15), pvr.dvbviewer (65b86471, +12), pvr.filmon (5d1a5c13, +12), pvr.hts (78a6bd68, +34), pvr.iptvsimple (353cb28d, +12), pvr.mediaportal.tvserver (0de32b2b, +26), pvr.mythtv (30b40c93, +51), pvr.nextpvr (a731f3c4, +15), pvr.njoy (43b4698f, +12), pvr.pctv (ff5d5360, +12), pvr.stalker (b8a61cb8, +12), pvr.vbox (48ebfdae, +24), pvr.vdr.vnsi (8dedf209, +11), pvr.vuplus (0702fc50, +14), pvr.wmc (e87f1328, +14)
- Exclude kodi-100.10-handle-SIGTERM.patch: Use updated Kodi patch from stefansaraev repo
- Include b24d9e06: handle SIGTERM
- Include patch: Fix devinput 18b8ba44
- Include patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include patch: Add experimental splash video
- Include patch: Enable pvr addons, disable PVR updates
- Include PR:4228: ffmpeg: update to ffmpeg-2.7.1
- Include PR:7462: added: hide thumbs for unwatched episodes option to show plot is off
- Revert 25a51dad: Not yet ready for prime time
Build Highlights:
- Kodi 16.0a2
Build Details:
- XBMC:
- CProgressJob: fix crash in DoModal after 658b0a21ed4a7443d6670fc6180d8dc2e9b2ca47 (PR:7680, 3 commits, 1 file changed)
- bump to 16.0a2 (PR:7681, 1 commit, 2 files changed)
- [binary addons] fix/support ZIP packaging (PR:7641, 5 commits, 7 files changed)
- [guilib] fix textbox textcolor not properly set (PR:7671, 1 commit, 1 file changed)
- [settings] support minimum/step/maximum in lists (not only spinners) (PR:7592, 3 commits, 3 files changed)
- [gitignore] don't clean Makefile in xbmc/main/posix/ (PR:7685, 1 commit, 1 file changed)
- [binary addons] make addon source tarball caching option by introducing the ADDON_TARBALL_CACHING option (PR:7614, 2 commits, 2 files changed)
- [Confluence][PVR] EPG data area in PVR timer window. (PR:7630, 2 commits, 3 files changed)
Any build after 0727 results in movies either playing too fast, freezing or having no sound. I haven't tried a clean install but rolling back to 0727 solves the problem for me.
(2015-07-17, 23:35)Milhouse Wrote: [ -> ]Could Hifiberry Digi and Hifiberry Digi+ owners confirm if they are still having problems (as originally reported here) when using the latest build, thanks.
I have a Raspberry Pi 1 model B (512Mb) with Hifiberry Digi.
I just installed #801 and I can confirm that the problem is solved.
Thank you very much.
It seems there's not much improvement in playback problem of x265/HEVC in recent builds. The video freeze-pixelation-recovery sequences happened over a dozen times during playback of a 40 minutes episode. Most of the time, the video freeze could recover by itself after a few seconds and continue playback. Only in a few occasions the RPi2 just hanged.
However there is no movies playback problem mentioned by @
rob77 for me. In fact, build #0801 did fix a DTS audio track problem. The problem starts with lost of audio and then followed by video freeze. I knew it was the DTS audio track as after I replaced it with HE-AAC audio track, it plays flawlessly until the end. I tried to rolled back to 5.0.1 but problem persisted. With build #0801, this problem just gone.
BTW, I tried to disable the de-interlace feature to see if it helps to fix the x265/HEVC playback problem but I couldn't found how to turn it off in the setup menu.
Just getting round to setting up my brother's RPi v2 with Hifi Berry DAC.
It had a very old build #503 installed so I updated to #801. There's no sign of the DAC in the settings though and no snd entries in dmesg.
I've posted the dmesg
http://pastebin.com/iUvn4kcg and kodi.log
http://pastebin.com/kFuLdWtX
Do I need to add something to cmdline.txt or config.txt to make the DAC work?
It might be a known thing but I found my remote's OK/Select button was not doing anything and checking the logs showed it was now registering as
16:09:40 81.006470 T:1967362048 DEBUG: LIRC: Update - NEW at 73702:1c 0 KEY_ENTER devinput (KEY_ENTER)
16:09:40 81.006721 T:1967362048 DEBUG: OnKey: 22 (0x16) pressed, action is FullScreen
so I just edited Lircmap.xml to change the last line to <enter>KEY_OK</enter> to match the existing line for <select>KEY_OK</select> and added an extra line to my remote.xml so it now has
<select>Select</select>
<enter>Select</enter>
and it seems to be OK now. Thinking about it though, maybe it would have made more sense to add <select>KEY_ENTER</select> to Lircmap.xml and not add the<enter> line to remote.xml?
For the overclock, I currently have:
arm_freq=1000
core_freq=500
sdram_freq=500
over_voltage=6
over_voltage_sdram=4
but I seem to recall reading that there's not much point in OC'ing sdram on the v2, so shall I delete the sdram_freq=500 and over_voltage_sdram=4 lines and maybe drop over_voltage to 4 instead fo 6?
(2015-07-28, 19:35)MrNice Wrote: [ -> ] (2015-07-27, 19:58)MrNice Wrote: [ -> ] (2015-07-27, 13:58)popcornmix Wrote: [ -> ]Install the Leopold OE updater addon and find the first build with the problem. You can probably do this in fifteen minutes. With this information you are much more likely to get a fix.
I did some tests, all with the same process, no setup change:
Directory in SD with inside 7 audio files (see post #276)
Install new build with add-on, go to the directory in the SD, move the selection on the file, wait 15 seconds, read value from ssh/top, move to the next file.
Results:
Build | low CPU% (good files) | High CPU% (bad files)
#19852 (date: 22/Dec) | 15 | 66
#19882 (date: 01/Jan) | 15 | 65
#20173 (date: 01/Feb) | 15 | 69
#0301 | 15 | 70
#0401 | 67 | 69
#0501 | 66 | 81
#0601 | 59 | 62
#0701 | 64 | 64
#0401 | 63 | 66 (again to be sure)
#0726 | 09 | 95 (again to be sure)
My conclusion as a user:
2 type of files
Builds #0501 and #0726 have higher values.
I'll try to find the last change between #0701 and #0726
I found the starting build:
#0712 | 64 | 65
#0713 | 72 | 95
Even there is a difference between "bad" and "good" file (I don't know why) there is also a difference between builds.
I'll try to find out why the difference between files.
Just a reminder.
Build #0801 still has the same issue
(2015-08-02, 17:40)doveman2 Wrote: [ -> ]and maybe drop over_voltage to 4 instead fo 6?
over_voltage=4 is the maximum value for the Pi2 - anything higher will be interpreted as 4.
Regarding the OK/ENTER problem, attempts are being made to fix this (it's the reason the OE6 release is delayed). I've had to drop one commit as this seems to break working installs, hopefully there will be a solution soon.
New OpenELEC Jarvis build #0802:
RPi /
RPi2
# uname -a
Linux rpi512 4.1.3 #1 Sun Aug 2 21:03:54 BST 2015 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150802210304-#0802-g2fa61b7 [Build #0802]
001557.374: Kernel trailer DTOK property says yes
Based on tip of
XBMC master (6f1362f7,
- Includes latest libnfs master (2288339e, ahead +27)
Build Highlights:
- libnfs 1.9.8
- Kodi splash image fixes
Build Details:
- XBMC:
- [python] add 'mediatype' info label and remove implicit sets (PR:7683, 1 commit, 4 files changed)
- [gui][fix] progress dialog's canceled is never reset (PR:7678, 1 commit, 2 files changed)
- [guilib] use label2 to display the radiobutton value instead of a texture (PR:7686, 2 commits, 4 files changed)
- [guilib] update label color for sliderex controls (PR:7691, 1 commit, 1 file changed)
- FFmpeg: Bump to 2.7.2-Jarvis-alpha1 (PR:7696, 1 commit, 1 file changed)
- [dx11] DXVA fixes (PR:7647, 2 commits, 2 files changed)
- [pvr] Point add-ons to master instead of SHA (PR:7702, 1 commit, 17 files changed)
- [Confluence] - make use of new parametrized includes for weather part (PR:7653, 1 commit, 1 file changed)
- [splash] handle splash as regular window (PR:7650, 9 commits, 15 files changed)
- [dvdplayer][subs] Add "none" to the preferred language list. It will … (PR:7613, 2 commits, 3 files changed)
- sync scrapers with repo (312f1e17)
- libnfs:
- bootstrap: create m4 directory (PR:120, 1 commit, 1 file changed)
- New version 1.9.8 (8f06fc9d)
- newclock4:
- Commits no longer in build:
- [settings] Fix broken network.bandwidth setting (27d81ebd)
I get a blank homescreen after the Kodi/Jarvis splash on #802. I can see notifications (library updates), and the power context menu still works. It might be the skin i'm using (mimic). I'm going to try rolling back to #801
EDIT:
I was able to switch back to confluence. Kodi works now. I guess something changed in the skin engine?
Build #802
I have (2) Rpi2, one works the other fails to boot with overclock enabled. Works with overclock disabled.
Kernel Panic with overclock
Worked fine on ~#726
arm_freq=1000
core_freq=500
avoid_pwm_pll=1
dtoverlay=sdhost,overclock_50=100
over_voltage=2
(2015-08-03, 00:55)Mfleigle Wrote: [ -> ]I get a blank homescreen after the Kodi/Jarvis splash on #802. I can see notifications (library updates), and the power context menu still works. It might be the skin i'm using (mimic). I'm going to try rolling back to #801
EDIT:
I'm not home right now so haven't seen this build boot. Do you see similar results with any other third-party skins? Do you still have a problem with mimic if the Kodi splash screen is disabled in as.xml?
<splash>false</splash>
(2015-08-03, 01:32)Milhouse Wrote: [ -> ] (2015-08-03, 00:55)Mfleigle Wrote: [ -> ]I get a blank homescreen after the Kodi/Jarvis splash on #802. I can see notifications (library updates), and the power context menu still works. It might be the skin i'm using (mimic). I'm going to try rolling back to #801
EDIT:
I tried xperience1080 and it had the same problem.
Although I was able to get the home screen to appear if I went to system info or settings and returned to home.
Adding
Seem to make the OS freeze.
