(2015-08-24, 23:33)herrmeier01 Wrote: [ -> ]Rpi1 (first generation 256MB) working just fine
Rpi1 (2nd generation 512MB) not working (same SD-Card as above)
Rpi2 (same build/firmware) not working
Useful bit of info. On my pi2 with:
total_mem=256
gpu_mem=128
Your VC1 file (and the others) play without corruption.
Now there is a restriction with h.264 videos that all the picture buffers need to be within the same 256M chunk of memory.
I wonder if there is something similar with VC-1 that is not being enforced.
Anyway - a useful data point for debugging.
New OpenELEC Jarvis build #0824:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.6 #1 Mon Aug 24 22:11:25 BST 2015 armv6l GNU/Linux
# vcgencmd version
Aug 23 2015 19:27:51
Copyright (c) 2012 Broadcom
version 41b1f861989dc4d1bbe19a52361a248ae57ee82b (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150824221036-#0824-gc06668c [Build #0824]
# vcdbg log msg 2>&1 | grep DTOK
001574.747: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (c06668c5,
changelog) and tip of
XBMC master (183b2138,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78, ahead +2)
- Includes latest libcec master (e8506b3d, ahead +29)
- Includes latest libnfs master (aea3b9be, ahead +30)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (da6ee5dd), adsp.biquad.filters (b6a31a90), adsp.freesurround (4dd3202f), asplib (490de460), pvr.argustv (8edcbd25, +24), pvr.demo (039972ea, +15), pvr.dvblink (79cc2d3c, +17), pvr.dvbviewer (2af87049, +15), pvr.filmon (57c7de00, +14), pvr.hts (d2763613, +46), pvr.iptvsimple (14e2d589, +14), pvr.mediaportal.tvserver (4e4b0f4e, +28), pvr.mythtv (0e3e0254, +62), pvr.nextpvr (c09bc2ab, +17), pvr.njoy (91fdbd98, +14), pvr.pctv (b37de304, +14), pvr.stalker (dd3aaf85, +14), pvr.vbox (5273f25f, +26), pvr.vdr.vnsi (73de793a, +14), pvr.vuplus (11529b2e, +16), pvr.wmc (48c37c04, +16)
- Exclude kodi-100.10-handle-SIGTERM.patch: Use updated Kodi patch from stefansaraev repo
- Exclude kodi-999.99-Isengard-backports.patch: Merged upstream
- Exclude kodi-theme-Confluence-999.99-Isengard-backports.patch: Merged upstream
- Exclude linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent
- Include dd9ec795: Add crossguid package
- Include e8a5ea91: (jarvis) taglib: update to taglib-1.9.1
- Include patch: Add crossguid dependency
- Include patch: Fix PR7462 after PR7833
- Include patch: handle SIGTERM (updated due to singleton/PR7833)
- Include patch: Fix singleton/PR7833 changes
- Include patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include patch: Fix devinput 18b8ba44
- Include patch: Add experimental splash video
- Include patch: Enable pvr addons, disable PVR updates
- Include patch: Update with latest version of pull request
- Include PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include PR:4228: ffmpeg: update to ffmpeg-2.7.1
- Include PR:4266: [systemd] update to systemd-224
- Include PR:4284: [Python] update to 2.7.10
- Include PR:4286: remove unused python stuff
- Include PR:7462: added: hide thumbs for unwatched episodes option to show plot is off
- Include PR:7783: [binary addons] use TARGET_LINKER_FILE_NAME as library filename
- Include PR:7861: [settings] ensure year string is at the end in clean datetime regexp
- Include PR:7872: [peripherals] replace peripherals manager with dialogselect
- Include PR:7878: dvdplayer: set default screen region for dvb subs
- Revert PR:4285: buildsystem cosmetics (Reason: DevUpdate addon needs updating, see issue #24)
Build Highlights:
- Additional seek fixes
Build Details:
- libnfs:
- build: add m4 directory to source tree (PR:125, 1 commit, 2 files changed)
- newclock4:
- New commits in this build:
- fixup! [mmalcodec] refector the decoder flags logic to avoid stalls on seek (35154652)
- fixup! [mmalcodec] refector the decoder flags logic to avoid stalls on seek (1c48054a)
Looks like build 0824 stopped the frame skipping with DVDPlayer and 720p content in full screen video mode.
Don't celebrate yet. If the GUI is up (channel guide with video scaled down or with main menu showing, the audio plays fine, but the video falls behind. When I go back to full screen, the video races to catch up with the sound. As Spock would say, fascinating. Seems to work fine as long as video is full screen. This was when watching live TV. When the video catches back up, the skip count increases rapidly as the video is racing (this actually makes sense to me).
(2015-08-25, 00:42)afremont Wrote: [ -> ]Looks like build 0824 stopped the frame skipping with DVDPlayer and 720p content in full screen video mode.
I did make a subsequent commit for this issue that didn't make this build, so it's possible it will behave better in tomorrow's build.
Okay, at least I can keep using DVDPlayer. It's much better than 0823 and seems to work fine full screen. Even when not full screen, or with GUI overlay (except the OSD codec info, for some reason it has no effect) it loses audio sync, but catches back up soon after going full screen again.
My rpi2 has for soms reason stopped accepting builds. Latest succesfully installed was 0822. Everything after that fails to install. It downloads the build, it reboots but instead of seeing the update progress, the screen comes up with the kodi splash screen followed by the window that a newer build is available. So I'm in sort of a loop.
Hey popcornmix, was there anything in my debug log that would explain an issue with my Hifiberry and the default video player? (dvdplayer)
http://xbmclogs.com/pbgtsxxqi
Quote:Hey. I'm not entirely sure if my current issue is to do with this build. I'm having issues with my Digi+, the system sounds work, but as soon as I start playing a video, I get no sound at all through the both toslink and digital outputs. With passthrough on and off. I was told it could be the dvdplayer backend is not using the soundcard. Is there any way for me to be able to see if this is the case? Or has anyone else experienced this?
I have used the guides from them with success, just this odd issue seems to be happening.
(2015-08-25, 01:01)Bartmaniac Wrote: [ -> ]My rpi2 has for soms reason stopped accepting builds. Latest succesfully installed was 0822. Everything after that fails to install. It downloads the build, it reboots but instead of seeing the update progress, the screen comes up with the kodi splash screen followed by the window that a newer build is available. So I'm in sort of a loop.
Are you using Leopolds Dev Update add-on to download builds? Did you read
this?
I still get hangs/lockups in Kodi GUI. Tried to open "Programs" and got this:
Same happened yesterday morning. System was IDLE for about 5 hours before the lockup.
"top" after lockup:
Then I killed kodi with SIGABRT ang got this Crashlog:
http://pastebin.com/y89c7WJZ
Looks like the hangs between 2 videos are fixed for me. Never seen it again, but this seems to be a different problem.
(2015-08-25, 12:20)gandharva Wrote: [ -> ]I still get hangs/lockups in Kodi GUI. Tried to open "Programs" and got this:
These are suspicious - but I don't know what they mean:
12:29:02 14.833411 T:1967108096 ERROR: Window Translator: Can't find window tv
12:29:02 14.841580 T:1967108096 ERROR: Window Translator: Can't find window pvrosddirector
12:29:02 14.841749 T:1967108096 ERROR: Window Translator: Can't find window pvrosdcutter
12:29:02 14.858982 T:1967108096 ERROR: Window Translator: Can't find window tv
12:29:02 14.867550 T:1967108096 ERROR: Window Translator: Can't find window pvrosddirector
12:29:02 14.867729 T:1967108096 ERROR: Window Translator: Can't find window pvrosdcutter
10:15:28 78400.914062 T:1967108096 ERROR: Window Translator: Can't find window peripherals
[code]
This is probably even more suspicious:
[code]
10:15:28 78401.015625 T:1967108096 NOTICE: SpawnThread - fatal error creating thread
#0 0x76d88f5c in pthread_cond_wait () from /lib/libpthread.so.0
#1 0x004d8a5c in CEvent::Wait() ()
#2 0x009b051c in CThread::SetPriority(int) ()
#3 0x0072a3a4 in CBackgroundInfoLoader::Load(CFileItemList&) ()
#4 0x006859c4 in CGUIWindowPrograms::Update(std::string const&, bool) ()
#5 0x0070470c in CGUIMediaWindow::Refresh(bool) ()
#6 0x0070ae40 in CGUIMediaWindow::OnInitWindow() ()
#7 0x00416420 in CGUIWindow::OnMessage(CGUIMessage&) ()
#8 0x0070acd0 in CGUIMediaWindow::OnMessage(CGUIMessage&) ()
#9 0x00685570 in CGUIWindowPrograms::OnMessage(CGUIMessage&) ()
#10 0x0041bc90 in CGUIWindowManager::ActivateWindow_Internal(int, std::vector<std::string, std::allocator<std::string> > const&, bool, bool) ()
#11 0x0041bee0 in CGUIWindowManager::ActivateWindow(int, std::vector<std::string, std::allocator<std::string> > const&, bool, bool) ()
#12 0x005c3650 in CBuiltins::ActivateWindow(int, std::vector<std::string, std::allocator<std::string> > const&, bool) ()
#13 0x005c42f8 in CBuiltins::Execute(std::string const&) ()
#14 0x00722780 in CApplication::ExecuteXBMCAction(std::string) ()
#15 0x007230c4 in CApplication::OnMessage(CGUIMessage&) ()
#16 0x004196cc in CGUIWindowManager::SendMessage(CGUIMessage&) ()
#17 0x0042bcc0 in CGUIAction::ExecuteActions(int, int) const ()
#18 0x0060e36c in CStaticListProvider::OnClick(std::shared_ptr<CGUIListItem> const&) ()
#19 0x0046569c in CGUIBaseContainer::OnClick(int) ()
#20 0x00415c80 in CGUIWindow::OnAction(CAction const&) ()
#21 0x00419bb0 in CGUIWindowManager::OnAction(CAction const&) const ()
#22 0x007204dc in CApplication::OnAction(CAction const&) ()
#23 0x005b9cc0 in CInputManager::OnKey(CKey const&) ()
#24 0x005baf4c in CInputManager::OnEvent(XBMC_Event&) ()
#25 0x007214fc in CApplication::OnEvent(XBMC_Event&) ()
#26 0x0096fa08 in CWinEventsLinux::MessagePump() ()
#27 0x00716ed4 in CApplication::FrameMove(bool, bool) ()
#28 0x00773cb0 in CXBApplicationEx::Run() ()
#29 0x007772a8 in XBMC_Run ()
#30 0x00329b38 in main ()
Also you have 165 threads running in your gdb log. That seems an awful lot. (In my debug environment I typically have between 20 and 30). Do you have a lot of addons installed?
(2015-08-25, 01:05)handbone Wrote: [ -> ]Hey popcornmix, was there anything in my debug log that would explain an issue with my Hifiberry and the default video player? (dvdplayer)
You seem to be using omxplayer which doesn't support hifiberry. Make sure you haven't disabled MMAL in video/acceleration settings.
(leaving omxplayer enabled should be okay as long as MMAL is also enabled).
(2015-08-25, 01:09)Milhouse Wrote: [ -> ] (2015-08-25, 01:01)Bartmaniac Wrote: [ -> ]My rpi2 has for soms reason stopped accepting builds. Latest succesfully installed was 0822. Everything after that fails to install. It downloads the build, it reboots but instead of seeing the update progress, the screen comes up with the kodi splash screen followed by the window that a newer build is available. So I'm in sort of a loop.
Are you using Leopolds Dev Update add-on to download builds? Did you read this?
Thanks for your help. The problemen was that my OpenELEC Dev Update version was still 4.8.0 so a very old onder that doesn't update itself automatically. Had to download the zip file manually. Now running 4.17.0 I guess when 4.17.1 or whatever next number comes out I have to get the latest zipfile manually downloadde.
(2015-08-25, 15:25)Bartmaniac Wrote: [ -> ]Thanks for your help. The problemen was that my OpenELEC Dev Update version was still 4.8.0 so a very old onder that doesn't update itself automatically. Had to download the zip file manually. Now running 4.17.0 I guess when 4.17.1 or whatever next number comes out I have to get the latest zipfile manually downloadde.
You should install install the repository from the zip, then install the addon from within the repository, and then the add-on will automatically update. If you install an add-on from a zip, it will never automatically update.
See the "Installation" section on
the Dev Update page (scroll down - don't click on the ".zip" link at the top of the page) to install the repository. Probably not necessary, but I'd uninstall your existing Dev Update add-on before adding the repository etc.
New OpenELEC Jarvis build #0825:
RPi /
RPi2
# uname -a
Linux rpi512 4.1.6 #1 Tue Aug 25 23:01:18 BST 2015 armv6l GNU/Linux
# vcgencmd version
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150825230028-#0825-gc06668c [Build #0825]
001575.892: Kernel trailer DTOK property says yes
Based on tip of
XBMC master (71212433,
- Includes latest addons: adsp.basic (da6ee5dd), adsp.biquad.filters (b6a31a90), adsp.freesurround (4dd3202f), asplib (490de460), pvr.argustv (8edcbd25, +24), pvr.demo (039972ea, +15), pvr.dvblink (79cc2d3c, +17), pvr.dvbviewer (2af87049, +15), pvr.filmon (57c7de00, +14), pvr.hts (d2763613, +46), pvr.iptvsimple (14e2d589, +14), pvr.mediaportal.tvserver (4e4b0f4e, +28), pvr.mythtv (0e3e0254, +62), pvr.nextpvr (c09bc2ab, +17), pvr.njoy (91fdbd98, +14), pvr.pctv (b37de304, +14), pvr.stalker (1c0ca594, +22), pvr.vbox (5273f25f, +26), pvr.vdr.vnsi (73de793a, +14), pvr.vuplus (11529b2e, +16), pvr.wmc (48c37c04, +16)
- Revert PR:7885: [binary addons] fix android by using TARGET_LINKER_FILE_NAME instead of TARGET_FILE_NAME
Build Highlights:
- Kodi updates
Build Details:
- XBMC:
- [binary addons] fix android by using TARGET_LINKER_FILE_NAME instead of TARGET_FILE_NAME (PR:7885, 1 commit, 1 file changed)
- [BUILTINS] CancelAlarmclock didn't understand silent as a parameter and with theā¦ (PR:7883, 1 commit, 1 file changed)
- Avoid access violations when a lib couldn't be loaded. (PR:7376, 1 commit, 6 files changed)
- [settings] ensure year string is at the end in clean datetime regexp (PR:7861, 1 commit, 1 file changed)
- dvdplayer: set default screen region for dvb subs (PR:7878, 1 commit, 1 file changed)
- pvr.stalker:
- bump player engine version to 1382 (PR:22, 1 commit, 1 file changed)
- fixes and improvements (PR:21, 7 commits, 17 files changed)
- Reverted: PR:7885: [binary addons] fix android by using TARGET_LINKER_FILE_NAME instead of TARGET_FILE_NAME
(2015-08-25, 00:42)afremont Wrote: [ -> ]Don't celebrate yet. If the GUI is up (channel guide with video scaled down or with main menu showing, the audio plays fine, but the video falls behind. When I go back to full screen, the video races to catch up with the sound. As Spock would say, fascinating. Seems to work fine as long as video is full screen. This was when watching live TV. When the video catches back up, the skip count increases rapidly as the video is racing (this actually makes sense to me).
Any change with last night's version?
